Hi Brandon, There are many CentOS 7 variants. Which version do you use? Early CentOS, such as 7.1, is incompatible with the latest CentOS 7.8. From my old memory (I don't use CentOS anymore, but unfortunately, I have to use Rocky), you must install the following packages. ---- snip snip --- libtirpc-devel libtirpc ---- snip snip --- And you only need to set ---- snip snip --- echo "TIRPC=YES" > configure/CONFIG_SITE.local ---- snip snip --- Then, one could compile Asyn without any issues. My default configuration of CONFIG_SITE is ---- snip snip --- echo "TIRPC=YES" > configure/CONFIG_SITE.local echo "LINUX_GPIB=NO" >> configure/CONFIG_SITE.local echo "DRV_USBTMC=NO" >> configure/CONFIG_SITE.local ---- snip snip --- However, it is also important to check your version of Asyn also. Also, I can give you a hint. Please check your libasyn.so with ldd. Here is my libasyn.so output ---- snip snip --- $ ldd ~/epics/debian-12/7.0.7/modules/asyn/lib/linux-x86_64/libasyn.so linux-vdso.so.1 (0x00007ffec91e2000) libdbCore.so.3.22.0 => /home/jeonglee/epics/debian-12/7.0.7/base/lib/linux-x86_64/libdbCore.so.3.22.0 (0x00007ff29bea3000) libCom.so.3.22.0 => /home/jeonglee/epics/debian-12/7.0.7/base/lib/linux-x86_64/libCom.so.3.22.0 (0x00007ff29be2d000) libtirpc.so.3 => /lib/x86_64-linux-gnu/libtirpc.so.3 (0x00007ff29bddc000) libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007ff29ba00000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007ff29bdba000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007ff29b81f000) libca.so.4.14.2 => /home/jeonglee/epics/debian-12/7.0.7/base/lib/linux-x86_64/libca.so.4.14.2 (0x00007ff29bd58000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007ff29bc79000) libreadline.so.8 => /lib/x86_64-linux-gnu/libreadline.so.8 (0x00007ff29bc21000) libgssapi_krb5.so.2 => /lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007ff29b7cd000) /lib64/ld-linux-x86-64.so.2 (0x00007ff29bff8000) libtinfo.so.6 => /lib/x86_64-linux-gnu/libtinfo.so.6 (0x00007ff29b79a000) libkrb5.so.3 => /lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007ff29b6c0000) libk5crypto.so.3 => /lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007ff29b693000) libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007ff29b68d000) libkrb5support.so.0 => /lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007ff29b67f000) libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007ff29b678000) libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007ff29b667000) ---- snip snip --- Best, Han On Wed, Jun 14, 2023 at 11:42 PM Torsten Bögershausen via Tech-talk <[email protected]> wrote:
-- Jeong Han Lee, Dr.rer.nat. Staff Scientist and Engineer Cell: +1 510 384 3868
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
