1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Alarm Problem
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 15 Jun 2023 13:03:22 +0000
Follow-up from direct emails:
Turned out to not be specific to the alarm GUI.
Pop-up dialogs in general would cause issues with keyboard/mouse input.
Changing between GTK2/3 made no difference.
In the end, the vncserver was the problem.
Using thinlinc as the remote desktop server and client, even attaching to the thinlinc server with a plain vnc client avoided these issues.
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sinclair, John via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, June 13, 2023 at 12:28 PM
Subject: [EXTERNAL] Alarm Problem
I'm having a problem with alarm tree. When I right click and choose "Add Component", the app performs a grab of the keyboard and mouse with the following result:
No keyboard input is accepted from the alarm tree popup window (where I may select the type and content)
No Keyboard or mouse input is seen by other Phoebus applications or external applications
The only input accepted is using the mouse to select the type (node or pv/s) or clicking the cancel or OK button in the popup window but at this point no new content has been entered so nothing may be added to the tree.
Has anyone seen anything like this?
I am accessing the system though vnc and see no other issues except for one that may be related. If I make a change in display builder
and exit without having already saved the change, I get a popup which allows me to save or discard changes but something has performed a keyboard and mouse grab and I have to kill the vnc session from a terminal to recover.
EPICS 7.0.7
Kubuntu
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.2 LTS
Release:        22.04
Codename:       jammy
5.19.0-38-generic #39~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC
Phoebus commit - 0b4e47a760649775f926438e08301933e60a5ef5
kafka_2.13-3.3.2
John Sinclair
Alarm Problem Sinclair, John via Tech-talk
Re: Alarm Problem Kasemir, Kay via Tech-talk
Prev: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Next: Re: cross-compiling v7.0.7 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Alarm Problem Kasemir, Kay via Tech-talk
Next: C++ std problem Mark Rivers via Tech-talk
ANJ, 15 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
