Hi, Xiaoqiang.
We also use this field for indicating element absorption edges.
I think you're idea would work. I'll keep it in mind in case my regex
solution proves unworkable.
I think it would require me to put some extra code in the pydm window
to have the QCheckBox state change modify the string.
On Wed, Jun 21, 2023 at 06:20:32AM +0000, Wang Xiaoqiang wrote:
> Hi Mark,
> Every ROI has a description field, e.g. R0NM.
> https://epics-modules.github.io/mca/mcaRecord.html#Region-Of-Interest_Fields
> It is of string type, normally used to indicate element absorption edges.
> I wonder if you can append the ophyd information to it. e.g. “FeK [hinted]"
> Best
> Xiaoqiang
> > On 12 Jun 2023, at 18:25, Wolfman, Mark via Tech-talk <[email protected]> wrote:
> > Hi, tech-talkers.
> > Apologies in advance if parts of this don't make sense, I'm not that familiar with EPICS yet.
> > I'm hoping to add a new region-of-interest field [1] to the MCA records used in an existing IOC for our DXP fluorescence detector.
> > Similar to the other ROI fields, I'd like to have ``20bmxmap4b:mca1.R0BH``.
> > This will be a 'bi' field that doesn't do anything in the IOC, but is used by bluesky/ophyd during staging to determine whether the specific ROI is hinted in bluesky (hence BH for "bluesky hint") [2] and is included in the calculations for summing ROI's across elements. I've added extra records to an IOC before, and so I tried adding this as a record but EPICS complained because my record name included a '.' character.
> > One solution is to add a record like "20bmxmap4b:mca1_R0BH", but this makes the Ophyd part more complicated since the Ophyd MCA support expects the ROI to have a ``.Rn`` prefix and then tries to append the ``BH`` on the end[3]. Adding a record like ``mca1_R0BH`` means I have to re-write the MCA support in ophyd so I'd prefer to use the ``mca1.RnBH`` PVs if I can.
> > The full IOC is available on gitlab, though it's presently a work in progress.
> > Looking forward to hearing any ideas on how to make this work.
> > Thanks,
> > Mark
> > [1] https://epics-modules.github.io/mca/mcaRecord.html#Region-Of-Interest_Fields
> > [2] https://blueskyproject.io/ophyd/user_v1/reference/signals.html#kind
> > [3] https://github.com/bluesky/ophyd/blob/0802c77ec973b0ba9f8554d3bcf3a3001def7f66/ophyd/mca.py#L14
> > [4] https://git.aps.anl.gov/20BM/20bmdxp/-/tree/main/
My work schedule may not be the same as your work schedule. Please
don't feel obligated to respond to this e-mail outside of your normal
work hours.
This message may be signed or encrypted with Pretty Good Privacy (PGP)
key BE1E3158.
https://keys.openpgp.org/vks/v1/by-fingerprint/BB98174E34193EDCEA0F423C457826FCBE1E3158
- add fields to an existing record Wolfman, Mark via Tech-talk
- Re: add fields to an existing record Wang Xiaoqiang via Tech-talk
Adding EPICS modules to conda-forge Thorne, Keith via Tech-talk
Re: MVME products discontinuation Andrew Johnson via Tech-talk
<2023>
2025
2026
Is HVCAENx527 Available Online for downloading? Weiwei Lu via Tech-talk
<2023>
2025
2026
