1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Which VMEbus CPU for EPICS7 and RTEMS?
From: Chris Johns via Tech-talk <[email protected]>
To: [email protected], Michael Davidsaver <[email protected]>
Date: Thu, 22 Jun 2023 09:50:23 +1000
On 22/6/2023 4:41 am, Joel Sherrill wrote:
> On Wed, Jun 21, 2023 at 12:54 PM Michael Davidsaver <[email protected]
> <mailto:[email protected]>> wrote:
>     On 6/21/23 06:57, Joel Sherrill via Tech-talk wrote:
>     > For NFSv4, you need libbsd which forces making sure there is
>     > a driver and configuration for the board you care about.
>     Does the need to use libbsd effect the availability/function of
>     the existing PCI drivers for the VME bridge chips?
>     Some conversations I've listened in on leave me with the impression
>     that libbsd also includes the BSD PCI driver framework.  It is not
>     clear to me how this would interact with the RTEMS PCI driver
>     APIs which I am familiar with.
> Chris can answer definitively but I think they should except maybe for
> interrupts. Most of the APIs are access and device id lookup.
The PowerPC PCI support is in the BSPs and that is used by LibBSD to map the
device PCI resources.
Chris
Which VMEbus CPU for EPICS7 and RTEMS? Heinz Junkes via Tech-talk
Re: Which VMEbus CPU for EPICS7 and RTEMS? Zimoch Dirk via Tech-talk
Re: Which VMEbus CPU for EPICS7 and RTEMS? Heinz Junkes via Tech-talk
Re: Which VMEbus CPU for EPICS7 and RTEMS? Joel Sherrill via Tech-talk
Re: Which VMEbus CPU for EPICS7 and RTEMS? Michael Davidsaver via Tech-talk
Prev: Re: Help creating IOC for Lakeshore 336 Lang, Keenan C. via Tech-talk
Next: Re: MVME products discontinuation Kazuro FURUKAWA via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Which VMEbus CPU for EPICS7 and RTEMS? Joel Sherrill via Tech-talk
Next: EPICS record name question Rolf Keitel via Tech-talk
