1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Strangeness in ai/mbbiDirect with StreamDevice on PINI
From: "Leblanc, Gregory via Tech-talk" <[email protected]>
Date: Mon, 26 Jun 2023 18:20:15 +0000
Hi folks,
I'm still working on getting these Heinzinger PCU 50-300 supplies doing everything I want using EPICS.  Today I thought I'd try reading the status word from the supply, so I added an mbbiDirect record.  The custom sections of my .db file now read:
record(ai, "$(P)$(R)GetCurrent") {
    field(DESC, "Read output current")
    field(DTYP, "stream")
    field(INP, "@devPCU50_300.proto getCurrent $(PORT) $(A)")
    # field(SCAN, "1 second")
    field(SCAN, "Passive")
    # field(PINI, "YES")
    field(EGU, "Amps")
    field(ESLO, "0.001")
    field(LINR, "SLOPE")
record(ao, "$(P)$(R)SetCurrent") {
    field(DESC, "Write output current")
    field(OUT, "@devPCU50_300.proto setCurrent(%d) $(PORT) $(A)")
    field(PINI, "YES")
    field(VAL, "0")
    # field(FLNK, "$(P)$(R)GetCurrent")
    field(EGU, "Amps")
record(mbbiDirect, "$(P)$(R)StatusRegister") {
    field(DESC, "Status Register")
    field(NOBT, "24")
    field(INP,  "@devPCU50_300.proto getStatus $(PORT) $(A)")
    field(PINI, "YES")
But I'm seeing some unexpected behavior, somehow related to my other records.  Above, the PINI field for the GetCurrent record is commented out.  When I start the IOC in this state, the StatusRegister record is properly populated.  If I set PINI to YES and start the IOC, the StatusRegister record is not properly populated.  Running the command 'dbtr PCU50_300testStatusRegister' on the "broken" startup will update it so that it has the correct status.  I've watched the console output when launching st.cmd, and browsed the logfiles that I generated, but I can't spot what I'm doing wrong.  I've attached a logfile where I have the problem, and another where I don't.  I've also attached the .db file, the .proto file, and my st.cmd, all in a .7z file.
I feel like the root cause is that somehow the replies to the different serial commands are getting mixed up, but I can't see how that's possible.  It is more likely that I've done something silly along the way.  Any hints for troubleshooting are greatly appreciated!
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
Attachment: pini_trouble.7z
Description: pini_trouble.7z
Prev: Re: Strange time consumption in multi thread CA Client program Sinclair, John via Tech-talk
Next: Strangeness in ai/mbbiDirect with StreamDevice on PINI Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
