1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: has anyone used ADPICam in a docker?
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 28 Jun 2023 20:52:37 +0200
did you give the container access to the device?
you can do this with either `--device <path/to/device/on/host>` or as volume `-v <path/to/device/on/host>`
Am 28.06.2023 um 20:49 schrieb Lee L. Yang via Tech-talk:
I'm trying to run the following IOC:
in a docker image.
The IOC runs fine outside of docker, on ubuntu 22.04.
But when I start the same IOC, the camera can not be found.
The communication to the camera is via USB port.
The camera model is Princeton Instruments, MTE3, CCD camera.
Lee Yang
Lawrence Berkeley National Lab
1 Cyclotron Road,  M/S 15R0217
Berkeley, California 97320
office:(510)486-7320
has anyone used ADPICam in a docker? Lee L. Yang via Tech-talk
Prev: has anyone used ADPICam in a docker? Lee L. Yang via Tech-talk
Next: Senior Controls Engineer Position at Sigray Ernesto Paiser via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
