1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Adding EPICS modules to conda-forge
From: Simon Rose via Tech-talk <tech-talk at aps.anl.gov>
To: "Thorne, Keith" <kthorne at caltech.edu>, GAGET Alexis via Tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 4 Jul 2023 06:45:18 +0000
Hi Keith –
There are some EPICS modules that are in conda, but they use a variant of e3 (which is a variant of PSI’s require module) for their build, packaging, and configuration. We are using them for some prototype work at ESS.
These are currently hosted on an ESS-hosted artifactory. If you have any questions about this and if this might suit your needs, we could probably arrange a short meeting to discuss this.
Cheers,
Simon
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Thorne, Keith via Tech-talk" <tech-talk at aps.anl.gov>
Reply to: "Thorne, Keith" <kthorne at caltech.edu>
Date: Wednesday, 21 June 2023 at 17:04
To: GAGET Alexis via Tech-talk <tech-talk at aps.anl.gov>
Subject: Adding EPICS modules to conda-forge
At LIGO we have started using conda for Debian, Rocky Linux workstations and soft IOCs.
Several EPICS packages are already on conda-forge , like epics-base, epics-extensions, etc
However, the modules in https://github.com/epics-modules do not appear to be there.
In particular, the ‘pcas’ module that used to be part of EPICS base in older versions is not available.
So is anyone coordinating EPICS package requests to conda-forge?
I would like to see pcas, asyn, modbus, calc, opcua
Sincerely
Keith Thorne
Keith Thorne <kthorne at caltech.edu>
CDS Software Engineer
LIGO Livingston Laboratory
Livingston, LA 70754
Phone: (225)686-3168 Fax: (225)686-7189
Adding EPICS modules to conda-forge Thorne, Keith via Tech-talk
Prev: Re: Looking for LV-EPICS BIndings CALab Installer, Looking for OceanOpics Spectrometer Driver Michael Davidsaver via Tech-talk
Next: Issue with streamdevice and I/o Intr Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Adding EPICS modules to conda-forge Thorne, Keith via Tech-talk
Next: Help creating IOC for Lakeshore 336 Brandon Gunn via Tech-talk
ANJ, 04 Jul 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
