There are several ways, depending on your needs and environment.
You can simply make the display files read-only, or copy them from the location where you edit them into a read-only “production” area.
There’s usually the issue that you want to reach the production displays not only from the control room network but also from offices (using a read-only gateway for the PVs). That can be accomplished by sharing
them via NFS/SAMBA/… or via an http:// file server (which by its nature is read-only).
With such read-only files, it’s usually still desirable to include the editor in CSS because that way anybody with some artistic talent can open the files in the editor, improve them, save the new files in
some other location (since the production area is read-only) for their own use, or contact the appropriate people to get the improved display file installed into the production area.
If you are convinced that your end users won’t be able to offer any improvements, you can provide them with a crippled version of CSS that doesn’t include the editor. Simply delete the lib/app-display-editor-*.jar
from a pre-built binary. Eventually build your own site-specific binaries, see
https://github.com/ControlSystemStudio/phoebus/blob/master/phoebus-product/README.md
As for different roles, see
https://docs.epics-controls.org/en/latest/specs/AccessSecurity.html
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Eusebio Naif Al-Soliman Fuentes via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, July 6, 2023 at 6:52 AM
To: Tech Talk <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Information about the deployment of CSS Phoebus
With that, you get an IDE and some tools to manage and control your EPICS variables and IOC devices and create some panels in order to control your facility.
However, if I want to deploy my panels in a production environment, how can I do that? There must be a way to create an executable that launches the panels without the possibility
to edit them.
Additionally, there should be a way to implement a users control with several roles such as 'operator', 'technician' and so on, each one with different privileges. Could someone
give me more information about that?
Saludos/Best regards
University of Granada
MSc.
Data Science and Computer Engineering
eunaif at correo.ugr.es
