1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Help generating envPaths
To: "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Wed, 19 Jul 2023 13:56:02 +0000
You need to check the ARCH in the iocMobipix directory. If it does not match EPICS_HOST_ARCH then it won’t build envPaths.
Sent from my iPhone
On Jul 19, 2023, at 8:46 AM, Marco A. Barra Montevechi Filho via Tech-talk <[email protected]> wrote:
Hello, all
Im trying to compile and use a custom IOC which is an areaDetector module.
For some reason, the  IOC compilation does not generate an envPaths file. The directory structure is like:
├── capture
├── configure
├── iocs
│   └── mobipixIOC
│       ├── configure
│       ├── iocBoot
│       │   └── iocMobipix
│       └── mobipixApp
│           ├── Db
│           └── src
└── mobipixApp
    ├── Db
    ├── DOCS
    ├── op
    │   ├── adl
    │   ├── edl
    │   │   └── autoconvert
    │   ├── opi
    │   │   └── autoconvert
    │   └── ui
    │       └── autoconvert
    └── src
The TOP folder has configure/RELEASE and configure/RELEASE.local with some paths defined.
I also tried compiling the whole application, cd into iocs/mobipixIOC/iocBoot/ and make, but i get:
make: Nothing to be done for 'all'.
The makefile in the folder is:
TOP = ../..
include $(TOP)/configure/CONFIG
ARCH = linux-x86_64
TARGETS = envPaths cdCommands dllPath.bat
include $(TOP)/configure/RULES.ioc
Am i forgetting to edit some file?
Thanks in advance for any help 🙂
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Help generating envPaths Mark Rivers via Tech-talk
Help generating envPaths Marco A. Barra Montevechi Filho via Tech-talk
Prev: Help generating envPaths Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Help generating envPaths Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
