1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Need help with Phoebus Alarm E-logger and Interface to the E-mail
From: Charles Jenkins via Tech-talk <[email protected]>
To: Phoebus Tech Talk <[email protected]>
Date: Fri, 21 Jul 2023 08:57:47 -0500
Hello All,
My name is Merrill Jenkins and I am working on the Fermilab Mu2e Experiment.
I have been working on adapting CSS Phoebus to monitor and control the Cosmic Ray Veto (CRV) for this experiment.  Currently, there are no electronics or software installed for the CRV at the experiment, so I have put together a simulated system that uses an EPICS solftIoc.  I have been able to set up Phoebus to display read-back values for the elements of the CRV detector.  I have been able to setup the alarm-server for these elements. (I have installed zookeeper, kafka and I have been able to configure the alarms with alarm-server.sh.)  The alarm tree is populated, the alarm area panel works, the annunciation panel works and so does the alarm table.
Phoebus will run for a while and then hang, especially if I change the value of an element so that it trips an alarm.  It seems that Phoebus will hang if there are problems with the alarms package.  I think, that in this case, the program stops working because the alarm package wants to log this change.  (But, I could be wrong.) So I am trying to setup the alarm-logger.  However, I am not making any headway with setting up the alarm-logger.  Over the past year I have looked over posted documentation and was able to solve many problems  However, I don't see any hints in the documentation on how to setup the alarm-logger after installing elasticserver.  Could someone point me to how to set up the alarm-logger?  (Also, if this is not the problem, could someone point me to what this problem might be and how to solve it?)
A second issue, is how to include the electronics logbook (we are using ECLAPI) into Phoebus for possible direct entries from Phoebus.  I see that there are several packages including "elog" and "olog".  Is there an easy way to adapt a new electronic logbook so that it may be accessed by Phoebus?
Many thanks in advance for any help.
Merrill Jenkins
Merrill Jenkins
Professor of Physics
==== Mailing Address ====
Physics
411 University Blvd. N.
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Fax:  251.460.6800
Re: Need help with Phoebus Alarm E-logger and Interface to the E-mail Giovanni Savarese LNL via Tech-talk
Re: [EXTERNAL] Need help with Phoebus Alarm E-logger and Interface to the E-mail Kasemir, Kay via Tech-talk
Prev: NTEnum Gabriel Fedel via Tech-talk
Next: Re: Need help with Phoebus Alarm E-logger and Interface to the E-mail Giovanni Savarese LNL via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: NTEnum Gabriel Fedel via Tech-talk
