The DVAL is the position field that is usually autosaved. The readback
fields (RBV, DRBV, and RRBV) are not writable and cannot be restored by
autosave.
The setPosition method of a model-3 motor driver is called when an
autosaved position is restored. The position argument should be the
DVAL to be restored divided by the MRES, which should have units of steps.
What happens when the setPosition method sends the command to the
controller to redefine the position is obviously controller-dependent.
The RMP and REP fields are usually updated by queries of the theoretical
(motor) and feedback (encoder) positions in the controller or axis poll
methods.
Whether or not the motor record accepts the restored position depends on
the RSTM field. The "normal" motor record behavior is discard the
restored position if the controllers position is sufficiently non-zero
(>RDBD). This results in setPosition not being called.
I don't know why the RMP/REP fields would change when setting using SET
to redefine the VAL field, but not when VAL was restored by autosave.
I do have some questions, however:
1. What is the value of the FOFF field? Does OFF remain constant when
restarting the IOC?
2. Does the problem persist if the DVAL field is autosaved instead of
the VAL field?
3. What is the output of the following command after the IOC is done
booting:
epics> dbpr "xxx:m1", 9
Kevin
On 7/13/23 08:41, 岳宗仰 via Tech-talk wrote:
Hi, tech-talk,
I have a motion controller, and write driver support for it by model 3.
After power off, the pulse information and encoder counts of motor has
been lost, and we want to save this informations.
The setPosition(double position) has been rewrote.(I think this method
is used for autosave)
Through it, I can reset the pulse counts at any position.
$caput xxx.m1.SET 1
$caput xxx:m1.VAL 0
So I use autosave module, and save the .RBV and .VAL PV.
After IOC and controller restart, the .RBV and .VAL PV has been changed,
But .RMP, .REP PV not changed and the register of pulse counts of
controller also not change.
Have you met this case?
I would appreciated some suggestions.
Zongyang yue
Thanks
- How to reset encoder counts after controller power off 岳宗仰 via Tech-talk
Re: archiver appliance - PVs not reconnecting Ralph Lange via Tech-talk
Re: archiver appliance - PVs not reconnecting Hu, Yong via Tech-talk
<2023>
2025
LINK_ALARM in records Florian Feldbauer via Tech-talk
<2023>
2025
