1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: AW: problem reading data from PLC
From: "Blomley, Edmund \(IBPT\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: "s7nodave-maintainer at oss.aquenos.com" <s7nodave-maintainer at oss.aquenos.com>, Abhishek Dutta <abhishek.d at vecc.gov.in>
Date: Mon, 7 Aug 2023 06:39:21 +0000
Hey,
in my experience errors like this point to an issue with either the PLC address itself (not valid/correct) or the PLC configuration. I am no expert on the PLC side of things, but if I remember correctly there are settings on the PLC both in general and on a channel level to allow/deny read or write access using s7nodave.
Cheers
Von: Tech-talk <tech-talk-bounces at aps.anl.gov> Im Auftrag von Abhishek Dutta via Tech-talk
Gesendet: Freitag, 4. August 2023 12:45
An: s7nodave-maintainer at oss.aquenos.com; tech-talk at aps.anl.gov
Betreff: problem reading data from PLC
Sir,
I've been trying to establish communication with S7 1500 PLC. Trying to read IW0, MD0.
While starting the IOC, I don't get any syntax error etc. The message shows following:
#!../../bin/linux-x86_64/myS7
< envPaths
epicsEnvSet("IOC","iocmyS7")
epicsEnvSet("TOP","/ics/tools/myS7")
epicsEnvSet("ASYN","/ics/tools/asyn4-38")
epicsEnvSet("S7NODAVE","/home/training/Desktop/ics/tools/s7nodave-3.0.2")
epicsEnvSet("EPICS_BASE","/ics/tools/base-7.0.6")
epicsEnvSet("ETHER_IP","/ics/tools/ether_ip")
epicsEnvSet("SNCSEQ","/ics/tools/seq-2.2.9")
epicsEnvSet("AUTOSAVE","/ics/tools/autosave-R5-10-2")
epicsEnvSet("STREAM","/ics/tools/StreamDevice-master")
epicsEnvSet("BUSY","/ics/tools/busy-1-6-1")
epicsEnvSet("PVXS","/ics/tools/pvxs")
epicsEnvSet("PYDEVICE","/ics/tools/PyDevice-R1.1.1")
cd "/ics/tools/myS7"
dbLoadDatabase "dbd/myS7.dbd"
myS7_registerRecordDeviceDriver pdbbase
#var mySubDebug 1
#traceIocInit
cd "/ics/tools/myS7/iocBoot/iocmyS7"
## Load record instances
#dbLoadTemplate "user.substitutions"
#dbLoadRecords "user.db"
< hall.cmd
s7nodaveConfigureIsoTcpPort("HallPLC","192.168.0.1",0,1,0)
s7nodaveConfigurePollGroup("HallPLC",'default',1.0,0)
s7nodaveConfigurePollGroup("HallPLC",'fast',0.1,0)
dbLoadRecords "hall1.db"
iocInit
Starting iocInit
## EPICS R7.0.6
## Rev. 2021-09-28T15:27-0400
## Start any sequence programs
#seq sncExample, "user=training"
epics> 2023/08/01 21:01:20.281 HallPLC error while reading 2 bytes from PLC address IB0.
2023/08/01 21:01:20.283 HallPLC error while reading 4 bytes from PLC address FB0.
IOC name is myS7 and following is the hall1.db file. It resides in the same st.cmd directory:
record(ai, "hall_ip1")
      field(SCAN,"1 second")
      field(DTYP,"s7nodave")
      field(INP, "@HallPLC(DLV=0,DHV=27648) IW0 int16")
      field(EGU,"V")
record(ai, "hall_uvolt")
      field(INP, "@HallPLC MD0 float")
      field(EGU,"V")
Please suggest solution for the same.
अभिषेक दत्ता/Abhishek Dutta
परिवर्ती ऊर्जा साइक्लोट्रॉन केन्द्र/Variable Energy Cyclotron Center
ईमेल/e-mail: abhishek.d at vecc.gov.in
Attachment: smime.p7s
Description: S/MIME cryptographic signature
problem reading data from PLC Abhishek Dutta via Tech-talk
Prev: problem reading data from PLC Abhishek Dutta via Tech-talk
Next: netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: problem reading data from PLC Sebastian Marsching via Tech-talk
ANJ, 07 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
