1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: epics-debhelper
From: Christoph Schroeder via Tech-talk <tech-talk at aps.anl.gov>
To: "Daykin, Evan" <daykin at frib.msu.edu>, "Blomley, Edmund (IBPT)" <edmund.blomley at kit.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 7 Aug 2023 11:12:40 +0200
Hi Evan,
that's great and you already made pull requests on epicsdeb. Is it possible to merge Martins last pull requests beforehand and maybe redo the pull request if it doesn't merge without conflicts? We are using this version (and 3.15.9 imported on top of that) as basis for our epics debian packaging and I think the newer versions of 3.15 should be in the git history.
Best regards,
Christoph
On 8/2/23 16:10, Daykin, Evan wrote:
P.S., I have Base 7.0.7 and submodules packaged if anyone would like it. I agree that some coordination at the next meeting might be helpful.
-Evan
From: Blomley, Edmund (IBPT) <edmund.blomley at kit.edu>
Sent: Wednesday, August 2, 2023 6:19 AM
To: Christoph Schröder <christoph.schroeder at helmholtz-berlin.de>
Cc: Daykin, Evan <daykin at frib.msu.edu>; tech-talk at aps.anl.gov
[EXTERNAL] This email originated from outside of FRIB
Hi Evan,
We are also still very much use Ubuntu and build our own Debian packages for EPICS base and modules (which are relevant for us), as well as various other (python) tools (such as pyepics, caproto, epicsdbbuilder, softioc). But we do not use epicsdeb for this, but have our own toolchain.
Due to some recent improvements in infrastructure we might be able to share these packages more easily and I was already looking into this. Maybe I will have an update on this for the next EPICS collaboration meeting.
Cheers,
Eddy
Am 01.08.2023 um 11:12 schrieb Christoph Schröder via Tech-talk <tech-talk at aps.anl.gov>:
Hi Evan,
I guess there is no active maintainer right now since the decline of Debian/Debian-packaging as basis for most facilities that run EPICS. We are still using basic EPICS/Debian-packaging at BESSY to setup client and server machines.
Your changes sound reasonable. I will test them in our build environment, but it's difficult for me right now so it might take some. Thanks for your work!
Best regards,
Christoph
--------------------Ursprüngliche Nachricht--------------------
Von: Daykin, Evan via Tech-talk <tech-talk at aps.anl.gov>
Gesendet: Montag 31. Juli 2023 21:17
An: tech-talk at aps.anl.gov
Betreff: epics-debhelper
Is anyone still taking care of epics-debhelper? I have a pull request fixing an issue with later lintian versions [1].
Cheers,
Evan
RE: epics-debhelper Daykin, Evan via Tech-talk
Re: epics-debhelper Christoph Schröder via Tech-talk
Re: epics-debhelper Blomley, Edmund (IBPT) via Tech-talk
Prev: netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Next: problem reading data from PLC S7NODAVE Abhishek Dutta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: epics-debhelper Ralph Lange via Tech-talk
Next: RE: epics-debhelper Daykin, Evan via Tech-talk
ANJ, 08 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
