1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: MRF EvtClk object not found
From: "Daykin, Evan via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 8 Aug 2023 21:51:16 +0000
Hello,
After upgrading our (test) timing master to Debian 12, the mrfioc2 module no longer recognizes the ‘EvtClk’ Object – consequently, the event clock running the show no longer functions. See output below – notably, the ‘Failed to open resource file…’ and the ‘failed to find/create object’ lines. Has anyone seen this issue before?
-Evan
cd "/usr/local/lib/iocapps/masterioc"## Register all support components
dbLoadDatabase "dbd/gtsmaster.dbd"
gtsmaster_registerRecordDeviceDriver pdbbase
MCoreUtils version 1.2.2
MCoreUtils: Read 0 thread rule(s) from /etc/rtrules
MCoreUtils: Read 0 thread rule(s) from /home/softioc/.rtrules
# mrmEvgSetupPCI(card id string, bus number, device number, function number)
mrmEvgSetupPCI("EVG1", "8:f.0")
Notice: devPCIFindSpec() expect B:D.F in hex
Device EVG1  8:f.0
Using IRQ 23
Failed to open resource file for PCI device 0000:08:0f.0: Permission denied
FPGA version: 24000008
cPCI-EVG-300 #Inputs FP:2 UV:4 RB:16
PCI interrupt connected!
mrmEvrSetupPCI("EVR1", "8:e.0")
Device EVR1  8:e.0 slot=(null)
Using IRQ 22
Failed to open resource file for PCI device 0000:08:0e.0: Permission denied
FWVersion 0x1402000b
Found version 11
Found SFP EEPROM
CompactPCI 6U: Out FP:0 FPUNIV:12 RB:0 IFP:2 GPIO:0
EVR FIFO task start
Enabling interrupts
## Load generic record instances
dbLoadRecords("/usr/lib/epics/db/save_restoreStatus.db", "P=iocgts-fts-mstr-n0001-evg:")
# picks up IOC, ENGINEER, LOCATION from environment vars
dbLoadRecords("/usr/lib/epics/db/iocAdminSoft.db", "IOC=iocgts-fts-mstr-n0001-evg")
dbLoadRecords("/usr/lib/epics/db/reccaster.db", "P=iocgts-fts-mstr-n0001-evg:")
## Load application-specific record instances
dbLoadRecords("db/cpci-evg-300.db", "SYS=GTS, SUB=FTS, DEV=MSTR, INST=N0001, D='', EVG=EVG1, ASGEXPERT=GTS_EXPERT")
dbLoadRecords("db/frib_seq.db", "SYS=GTS, SUB=FTS, DEV=MSTR, INST=N0001, D='', ASGEXPERT=GTS_EXPERT")
var(mrmGTIFEnable, 0)
iocInit()
Starting iocInit
EVR Current time provider NOT register
## EPICS R7.0.7-1~20230705105019.5+debian12
## Rev. 2023-07-05T07:15-0400
## Rev. Date build date/time:
… Autosave stuff omitted…
GTS_FTS:MSTR_N0001:FR_RSET_RFCL: failed to find/create object 'EVG1:EvtClk' : Object not found : EVG1:EvtClk
GTS_FTS:MSTR_N0001:FR_RSET_FSCL: failed to find/create object 'EVG1:EvtClk' : Object not found : EVG1:EvtClk
GTS_FTS:MSTR_N0001:FR_RSET_ECLK: failed to find/create object 'EVG1:EvtClk' : Object not found : EVG1:EvtClk
GTS_FTS:MSTR_N0001:FR_CSET_RFCL: failed to find/create object 'EVG1:EvtClk' : Object not found : EVG1:EvtClk
GTS_FTS:MSTR_N0001:FR_CSET_FSCL: failed to find/create object 'EVG1:EvtClk' : Object not found : EVG1:EvtClk
GTS_FTS:MSTR_N0001:CSRC_RCMD_ECLK: failed to find/create object 'EVG1:EvtClk' : Object not found : EVG1:EvtClk
GTS_FTS:MSTR_N0001:IRQ_RCMD_INP6: failed to find/create object 'EVG1:UnivInp4' : Object not found : EVG1:UnivInp4
GTS_FTS:MSTR_N0001:IRQ_RCMD_INP7: failed to find/create object 'EVG1:UnivInp5' : Object not found : EVG1:UnivInp5
GTS_FTS:MSTR_N0001:IRQ_RCMD_INP8: failed to find/create object 'EVG1:UnivInp6' : Object not found : EVG1:UnivInp6
GTS_FTS:MSTR_N0001:IRQ_RCMD_INP9: failed to find/create object 'EVG1:UnivInp7' : Object not found : EVG1:UnivInp7
GTS_FTS:MSTR_N0001:IRQ_RCMD_INPA: failed to find/create object 'EVG1:UnivInp8' : Object not found : EVG1:UnivInp8
GTS_FTS:MSTR_N0001:IRQ_RCMD_INPB: failed to find/create object 'EVG1:UnivInp9' : Object not found : EVG1:UnivInp9
GTS_FTS:MSTR_N0001:IRQ_RCMD_INPC: failed to find/create object 'EVG1:UnivInp10' : Object not found : EVG1:UnivInp10
GTS_FTS:MSTR_N0001:IRQ_RCMD_INPD: failed to find/create object 'EVG1:UnivInp11' : Object not found : EVG1:UnivInp11
GTS_FTS:MSTR_N0001:EN_RCMD: 'EVG1' lacks property 'Enable' of required type
GTS_FTS:MSTR_N0001:CSRC_CMD_ECLK: failed to find/create object 'EVG1:EvtClk' : Object not found : EVG1:EvtClk
Re: MRF EvtClk object not found Michael Davidsaver via Tech-talk
Prev: RE: epics-debhelper Daykin, Evan via Tech-talk
Next: Re: MRF EvtClk object not found Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Using opencv with areaDetector William Smith via Tech-talk
ANJ, 10 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
