1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: sscan build error
From: Vishnu Patel via Tech-talk <[email protected]>
To: "Tech Talk ([email protected])" <[email protected]>
Date: Tue, 29 Aug 2023 05:54:07 +0000
   I have an error compiling sscan-2-10-1 with epics base 7.0.7.   I am not able to understand how to resolve it.
../scanparmRecord.c:109:1: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
  109 | epicsExportAddress(rset, scanparmRSET);
In file included from ../../../../../base-7.0.7/include/dbBase.h:22,
                 from ../../../../../base-7.0.7/include/dbAccess.h:20,
                 from ../scanparmRecord.c:54:
../../../../../base-7.0.7/include/recSup.h:68:8: note: declared here
   68 | struct rset {   /* record support entry table */
../scanparmRecord.c: In function ‘process’:
../scanparmRecord.c:141:23: warning: unused variable ‘dbAddr’ [-Wunused-variable]
  141 |         struct dbAddr dbAddr;
../scanparmRecord.c:140:13: warning: unused variable ‘i’ [-Wunused-variable]
  140 |         int i;
../scanparmRecord.c:139:24: warning: unused variable ‘isRemote’ [-Wunused-variable]
  139 |         long status=0, isRemote=0;
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I../../../..//seq-2.2.5/include -I../../../../../base-7.0.7/include/compiler/gcc -I../../../../../base-7.0.7/include/os/Linux -I../../../../../base-7.0.7/include        -c ../recDynLink.c
../recDynLink.c:46:15: error: expected ‘;’ before ‘long’
   46 | epicsShareFunc long epicsShareAPI dbNameToAddr(const char *pname,struct dbAddr *);
../recDynLink.c:46:35: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘dbNameToAddr’
../recDynLink.c: In function ‘recDynLinkAddInput’:
../recDynLink.c:200:35: error: implicit declaration of function ‘dbNameToAddr’ [-Werror=implicit-function-declaration]
  200 |         if (options&rdlDBONLY  && dbNameToAddr(pvname,&dbaddr)) return(-1);
cc1: some warnings being treated as errors
make[3]: *** [../../../../../base-7.0.7/configure/RULES_BUILD:259: recDynLink.o] Error 1
make[3]: Leaving directory '/opt/epics/support/sscan-2-10-1/sscanApp/src/O.linux-x86_64'
make[2]: *** [../../../../base-7.0.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/opt/epics/support/sscan-2-10-1/sscanApp/src'
make[1]: *** [../../../base-7.0.7/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/opt/epics/support/sscan-2-10-1/sscanApp'
make: *** [../../base-7.0.7/configure/RULES_DIRS:85: sscanApp.install] Error 2
Thank you
Vishnu
Re: sscan build error Sandeep Kumar Malu - STFC UKRI via Tech-talk
Prev: RE: USBCTR08 ch0 scaler counts missing Mark Rivers via Tech-talk
Next: Re: sscan build error Sandeep Kumar Malu - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: areaDetector driver for BitFlow frame grabbers Mark Rivers via Tech-talk
