1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Sequencer
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: Ben Franksen <benjamin.franksen at helmholtz-berlin.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 30 Aug 2023 15:34:17 +0000
Hello!
Thank you very much for re-hosting the excellent documentation! However,
it seems the download links, at least for 2-2 tarballs, aren't
available. i.e.
https://epics-sequencer.sourceforge.io/releases/seq-2.2.9.tar.gz gets me
a 404 error.
Cheers,
Érico
On 15/08/2023 12:11, Ben Franksen via Tech-talk wrote:
> Hello everyone
> First, sorry for the long absence and not responding to messages, in
> particular those regarding the sequencer over the past years. I hope I
> will be able to take up proper maintenance from now on.
> Many of you noted that the sequencer website was unreachable lately.
> This is now fixed by giving it a new new home. The documentation and
> main entry point is now at
>   https://epics-sequencer.sourceforge.io/sequencer-2-2/
> (and similar for versions 2.1 and 2.3).
> The darcs repositories (also linked in the documentation) are at
>   https://hub.darcs.net/bf/seq-branch-2-2/
> Due to the attack on our IT infrastructure I have lost access to many
> E-Mails, especially during the last 3 months but also earlier ones. So
> I would like to ask you to please resend requests / comments / patches
> etc for which you never received a response. You can send them to me
> personally by email or to tech-talk, though in the latter case it will
> probably take a bit longer before I see them, since I am going to
> check the list only via RSS feed.
> Cheers
> Ben
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Sequencer Ben Franksen via Tech-talk
Prev: Re: Safely proceeding machine learning applications Zhang, Tong via Tech-talk
Next: Re: Safely proceeding machine learning applications Morgan Henderson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Sequencer Ben Franksen via Tech-talk
Next: asyn makeSupport.pl doesn't respect configure/RELEASE.local Leblanc, Gregory via Tech-talk
ANJ, 30 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
