A high-level workaround would be running a CA Gateway in front of the older IOCs. Might not be appropriate or possible in all situations, though.
In retrospect, dealing the CA version numbers should have been done when opening the TCP data circuit, but obviously that can't be changed retrospectively and without a protocol change.
Cheers, ~Ralph
- Problem with CA nameserver and CA_V413 protocol Brian Bevins via Tech-talk
- Re: Problem with CA nameserver and CA_V413 protocol Andrew Johnson via Tech-talk
Re: Streamdevice reads weird 1 byte null data Torsten Bögershausen via Tech-talk
Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Zimoch Dirk via Tech-talk
<2023>
Re: Problem with CA nameserver and CA_V413 protocol Michael Davidsaver via Tech-talk
<2023>
