1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Streamdevice reads weird 1 byte null data
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 20 Sep 2023 09:40:40 +0200
On Wed, 20 Sept 2023 at 08:48, Zimoch Dirk via Tech-talk <tech-talk at aps.anl.gov> wrote:
When not done correctly, 2-wire RS485 is prone to "echos" of the command you
send. A correctly made transceiver should disable its input while sending, but I
have had problems with newer MOXA DA-662 (but not older ones) re-enabling the
receiver too early. If MOXA uses the same chip in your nport 6650, it may be
unsuitable for 2-wire mode. You may want to try with a serial server from
another vendor.
Also,
depending on line length and communication speed, proper termination may be crucial.
Cheers,
~Ralph
Streamdevice reads weird 1 byte null data Hyung Jin Kim via Tech-talk
Re: Streamdevice reads weird 1 byte null data Zimoch Dirk via Tech-talk
Re: Streamdevice reads weird 1 byte null data Hyung Jin Kim via Tech-talk
Prev: 回覆: EPICS support for PI E-500 piezo controller Chiang, Liang-Chih [江良志] via Tech-talk
Next: Use sscan with transform record coordinate motion Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Streamdevice reads weird 1 byte null data Zimoch Dirk via Tech-talk
Next: Re: Streamdevice reads weird 1 byte null data Hyung Jin Kim via Tech-talk
ANJ, 21 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
