1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: update to Phytron motor support
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: Lutz Rossa <rossa at helmholtz-berlin.de>, tech-talk at aps.anl.gov
Date: Thu, 28 Sep 2023 09:16:14 -0500
Lutz,
The pull request has been merged.
Kevin
On 9/26/23 20:33, Lutz Rossa wrote:
Hello Kevin,
I would kindly ask to merge the pull request in case you did not get negative feedback. I've got no feed back via tech-talk nor email after starting this conversation.
Best regards,
Lutz
Am 24.07.23 um 16:20 schrieb Kevin Peterson:
Lutz,
Thanks for the pull request.
I would strongly encourage users of motorPhytron to test this.  I don't have any phytron controllers so if the code compiles and no one has any feedback, I'll merge the pull request.  The changes to the code look good to me.
Kevin
On 7/21/23 01:06, Lutz Rossa via Tech-talk wrote:
Hello,
we made some improvements to the support module for Phytron motor controllers (phyMOTION, www.phytron.eu).
Please have a look to this pull request and give feedback:
<https://github.com/epics-motor/motorPhytron/pull/7>
Best regards,
Lutz
update to Phytron motor support Lutz Rossa via Tech-talk
Re: update to Phytron motor support Kevin Peterson via Tech-talk
Re: update to Phytron motor support Lutz Rossa via Tech-talk
Prev: Re: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Érico Nogueira Rolim via Tech-talk
Next: Phoebus EDM autoconvert issue with a button widget Lucas Russo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: update to Phytron motor support Lutz Rossa via Tech-talk
Next: NTEnum Gabriel Fedel via Tech-talk
ANJ, 28 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
