1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Sequencer handling of waveforms with dynamic size
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 29 Sep 2023 14:46:33 +0200
On Fri, 29 Sept 2023 at 13:53, Jure Varlec via Tech-talk <tech-talk at aps.anl.gov> wrote:
Encountering this issue, I'm having a feeling of deja vu, so this might have been discussed before. But I can't find anything.
I found that a sequencer variable assigned to a waveform doesn't seem to know its current size. The pvCount() function always returns the value of NELM (or the array size of the sequencer variable, if smaller), not NORD. Is there some way to obtain the current size of the waveform that I missed? I'm not too keen on creating a separate variable assigned to the NORD field because there's no guarantee that the two variables will be in sync.
~Ralph
Re: Sequencer handling of waveforms with dynamic size Ralph Lange via Tech-talk
Sequencer handling of waveforms with dynamic size Jure Varlec via Tech-talk
Prev: EPICS Support for Microfocus X-ray tubes from X-RAY WorX Sintschuk, Michael via Tech-talk
Next: Re: Sequencer handling of waveforms with dynamic size Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Sequencer handling of waveforms with dynamic size Jure Varlec via Tech-talk
ANJ, 29 Sep 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
