Hi:
In your example EDM files, the “activeButtonClass” objects contain “controlBitPos” values to select a bit.
The converter looks for “controlBitsPos”,
https://github.com/ControlSystemStudio/phoebus/blob/d1183073c5929fbc454ef47dfcbdbce28cc7cd11/app/display/convert-edm/src/main/java/org/csstudio/display/converter/edm/widgets/Convert_activeButtonClass.java#L30
Looks like a typo that went unnoticed because nobody has tried to convert EDM files with bit-buttons before.
Check
https://github.com/ControlSystemStudio/phoebus/issues/2832 for updates
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Lucas Russo via Tech-talk <tech-talk at aps.anl.gov>
Date: Thursday, September 28, 2023 at 7:16 PM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Phoebus EDM autoconvert issue with a button widget
Hi all,
I'm trying to autoconvert an EDM file (.edl) to Phoebus (.bob) using the
Phoebus autoconvert feature.
It's mostly working, but the autoconverter doesn't seem to understand the
EDM Button Widget "Bit" field, in which it lets you set a single bit in a PV.
When I autoconvert this file, the generated .bob doesn't contain that information
and sets all buttons to the default bit "0".
I created a simple github repository with a minimal screen to reproduce the issue,
I'm using Phoebus 4.7.3-SNAPSHOT, build "master 2023-07-25 14:51"
Has anybody encountered a similar issue?
- Re: [EXTERNAL] Phoebus EDM autoconvert issue with a button widget Lucas Russo via Tech-talk
- Phoebus EDM autoconvert issue with a button widget Lucas Russo via Tech-talk
Re: Sequencer handling of waveforms with dynamic size Ralph Lange via Tech-talk
Re: Sequencer handling of waveforms with dynamic size Johnson, Andrew N. via Tech-talk
<2023>
<2023>
ANJ, 29 Sep 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
