1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Waveform data in a data storage system
Date: Tue, 17 Oct 2023 11:13:48 +0800 (GMT+08:00)
I was trying to store some waveform data using The EPICS Archiver Appliance, but the storage failed.
The PV names of the waveform data are as follows:
AC-LA-INJ1-BI:SBPM02-E:CH4_RAW_WAVEFORM
The error message is as follows:
61369 [JCA Command Thread] ERROR org.epics.archiverappliance.engine.pv.EPICS_V3_PV  - While processing a handleConnected for AC-LA-INJ1-BI:SBPM02-E:CH4_RAW_WAVEFORM.SCAN; the channel is not in a connected state.
63336 [PVNameDispatcherPVNameEvents 11] DEBUG org.epics.archiverappliance.engine.metadata.MetaGet  - Got value for NAME$ for pv AC-LA-INJ1-BI:SBPM02-E:CH4_RAW_WAVEFORM with timestamp Oct/13/2023 14:39:23 +08:00
61373 [PVNameDispatcherPVNameEvents 7] DEBUG org.epics.archiverappliance.engine.pv.EPICS_V3_PV  - Connection changed for pv AC-LA-INJ1-BI:SBPM02-E:CH4_RAW_WAVEFORM
61773 [JCA Command Thread] ERROR org.epics.archiverappliance.engine.pv.EPICS_V3_PV  - When trying to establish a subscription, there is already a subscription for AC-LA-INJ1-BI:SBPM02-E:CH4_RAW_WAVEFORM
I don't think there is a problem with the data storage system, other types of data can be stored normally. The server can also obtain data normally, what causes storage failure?
RE: Waveform data in a data storage system Žiga Oven via Tech-talk
Prev: Re: DBRecord <-> PVRecord data exchange Ignacio Arriagada via Tech-talk
Next: Re: Cross Compilation of Epics-base Navani Srivastava via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: process multiple lines with streamdevice Gerrit Kühn via Tech-talk
Next: RE: Waveform data in a data storage system Žiga Oven via Tech-talk
