1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: PVA connection problem
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 17 Oct 2023 16:06:29 +0200
Hello
Sorry for not citing the old messages. I just found the topic on tech-talk as I was looking for a strange behavior I observed when playing around with NDPluginPVA.
I was able to do a "pvget some_pv" on the machine where the IOC is running, but not on another machine. I had exactly the same ideas as commented here (adding ports 5075/5076 to the firewall) but without luck.
Then I started up wireshark and tested with and without firewall and figured out whats going on.
Without firewall:
Clients sends from port XXX to 5076
Server replies from port YYY to XXX
Client can read data!
With firewall:
Client replies with ICMP message
Server gives up, no data transfered!
Of course port XXX is not covered by the firewall rules and is random (> 50000 in my case). One can get around this if you open your firewall for all UDP traffic.
But that is not what you really want to do in a bigger network with lots of broadcast traffic. So opening ports 5075/5076 is not necessary.
So my hope is that one can force pvget/pvput to use a dedicated port that can be added to the firewall rules.
Jörn
Re: [EXTERNAL] Re: PVA connection problem Kasemir, Kay via Tech-talk
Prev: Re: DBRecord <-> PVRecord data exchange Érico Nogueira Rolim via Tech-talk
Next: Re: [EXTERNAL] Re: PVA connection problem Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: [EXTERNAL] PVA connection problem Ignacio Arriagada via Tech-talk
ANJ, 17 Oct 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
