1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: field transform is not found
To: "Tran, Phi Dung" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Oct 2023 23:40:05 +0000
Normally you get support fort he transform record by including the EPICS “calc” module dbd and lib files in your IOC app Makefile.
myApp_DBD +=  calcSupport.dbd
myApp_LIBS += calc
From: Tech-talk <[email protected]> On Behalf Of Tran, Phi Dung via Tech-talk
Sent: Thursday, October 19, 2023 4:38 PM
To: [email protected]
Subject: field transform is not found
Hello,
I am using transform in my field below, and got the message from st.cmd.
record(transform, "$(P)-TILT") {
    field(DESC, "tilt (tild ▲Θ mrad, us & ds mtrs, ")
    field(INPB, "$(P){upstream}RADIUS.VAL NPP NMS")
    field(CLCC, "a*b/1000") # r * ▲Θ/1000 =▲s
    field(CLCF, "c") # r * ▲Θ/1000 =▲s
    field(OUTC, "$(INBOARDMTR).VAL PP MS ")  # Output to upstream inboard and outboard, default is CA, for clarity for different IOC
    field(OUTF, "$(OUTBOARDMTR).VAL PP MS")  # Output to upstream inboard and outboard, default is CA, for clarity for different IOC
    #field(OUTC, "$(P){MoveUpstream} PP ")  # Output to upstream inboard and outboard, default is CA, for clarity for different IOC
    #get downstream radius, Tilt in -▲Θ direction
    field(INPD, "$(P){downstream}RADIUS.VAL NPP MS")
    field(CLCE, "-a*d/1000") # r * (-▲Θ)/1000 =▲s
    field(OUTE, "$(DOWNSTREAMMTR).VAL PP MS")  # Output to upstream inboard and outboard, default is CA, for clarity for different IOC
Error output ##########################################
Can't create record "XF:19IDC-ES-GO{Tilt}Mtr-TILT" of type "transform"
Error at or before ")" in file "/epics/iocs/virtMotorsMD3/db/galil0_pitch.db" line 112
Error: syntax error
dbLoadRecords: failed to load '/epics/iocs/virtMotorsMD3/db/galil0_pitch.db'
Makefile configuration ##############################
in my Makefile under src directory I have these statements,
virtMotorsMD3_DBD += devIocStats.dbd transformRecord.dbd
virtMotorsMD3_LIBS += motor softMotor
virtMotorsMD3_LIBS += devIocStats
virtMotorsMD3_LIBS += transforms10 userTransform userTransforms10 userTransforms10more userTransforms20
Can you give me suggestions what to do next,
P. Tran
field transform is not found Tran, Phi Dung via Tech-talk
Prev: modbus reading arrays of floats Pearson, Matthew via Tech-talk
Next: Re: modbus reading arrays of floats Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: field transform is not found Tran, Phi Dung via Tech-talk
Next: modbus reading arrays of floats Pearson, Matthew via Tech-talk
