1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: RE: Display Builder Web Runtime HTML pages
From: CAOUEN Loïc via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: Hasan SANSAR <hsansar at tarla.org.tr>
Date: Fri, 27 Oct 2023 06:50:42 +0000
Hello,
In CEA we use Apache to provide bob files from http.
Like that you can load bob files from http: instead of file:
Your URL would be
http://pcdbwr:8080/dbwr/view.jsp?display=http%3A%2F%2Fpcapache%2Fphoebus%2FTT472%2FView_TT472_RDC.bob&macros=%7B%7D
Then you can create an index.html in the "apache pc" containing an iframe or embed tag like that :
<embed id="display" src="http://pcdbwr:8080/dbwr/screen?display=http%3A%2F%2Fpcapache%2Fphoebus%2FTT472%2FView_TT472_RDC.bob&macros=%7B%7D"; width="100%" height="100%">
                </embed>
Regards
Loïc
-----Message d'origine-----
De : Tech-talk <tech-talk-bounces at aps.anl.gov> De la part de Hasan SANSAR via Tech-talk
Envoyé : jeudi 26 octobre 2023 15:03
À : tech-talk at aps.anl.gov
Objet : Display Builder Web Runtime HTML pages
I have built dbwr and pvwr with tomcat9. For showing .bob files, dbwr is generating a html files that has like address:
http://192.168.56.11:8080/dbwr/view.jsp?display=file:/opt/bob/fpga.bob&macros=%7B%22S%22:%22Value%20One%22,%22N%22:%221%22%7D
I want to show html files in only iframes, I should use Content-Security-Policy frame-ancestors for this and, tomcat9 has not built-in CSP.
Could I run this html file with .bob files from another PC? I think that if I can publish html files from another PC, I can control permissions for showing pages.
I got html sources and changed href attribute of link tags, src attribute of script tags, window.location.host parameter, file path from another PC is assigned to this html file in dbwr.load_content, but it didn't worked.
Thank you for your responses.
Hasan SANSAR
Display Builder Web Runtime HTML pages Hasan SANSAR via Tech-talk
Prev: Display Builder Web Runtime HTML pages Hasan SANSAR via Tech-talk
Next: Re: pvxs configuration problem Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: workQPanic-Kernel work queue overflow while attempting async communication and thereafter initializing tyGSOctalModule with vxWorks Mrinal Bera via Tech-talk
ANJ, 27 Oct 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
