Hi Phi,
You’re close, but I don’t think you can poke the motor record’s value into the dfanout that way.
One way you could do it is by processing the motor record, FLNK the motor record to the dfanout, and have the dfanout’s .DOL field set to the motor record’s .VAL field (NPP). That may not be the exact solution but that’s the direction
I would head.
Kurt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of
Tran, Phi Dung via Tech-talk
Sent: Tuesday, October 31, 2023 11:31 AM
To: tech-talk at aps.anl.gov
Subject: fanout is not working
I have created a virtual motor and can successfully use the `caput` and `caget` commands to set and read its value, respectively. However, my `dfanout` record is not moving the
motors with relative motions as expected. I have confirmed that the motors respond correctly when I use `caput` to directly interact with the fields in `dfanout`.
record(motor, "$(P)"){
field(DTYP, "Soft Channel")
field(DESC, "Move Y,ib,ob,ds mtrs")
# Where to write the setpoint to
# Output to upstream, inboard and outboard motors
field(OUT, "$(P)-F PP MS")
field(PREC,"7")
#Move Y motors ib,ob,ds in same direction
record(dfanout, "$(P)-F") {
field(DESC, "move ib,ob,ds MTR")
field(OUTA, "$(OUTBOARDMTR).TWF PP MS")
field(OUTB, "$(INBOARDMTR).TWF PP MS")
field(OUTC, "$(DOWNSTREAMMTR).TWF PP MS")
field(PREC, "7")
- RE: fanout is not working Pearson, Matthew via Tech-talk
- fanout is not working Tran, Phi Dung via Tech-talk
<2023>
2025
<2023>
2025
ANJ, 01 Nov 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
