Hi folks, We have been using in ALS the AlliedVision Manta G-145B cameras with areaDetector ADProsilica driver for several years . The G-145B cameras are used to capture beam spot images in ALS. This camera model is not produced any more so we are searching for an alternative. The AlliedVision suggested an alternative model: Manta G-235B with similar specification. Do any of you have experience with Manta G-235B cameras or other models which could be worth considering? Our requirements are: GigE standard pixel size under: 10um x 10umsensor size 2/3" update rate 10Hz 12 bits CCD/CMOS image size like: 1390x1038 triggerable with the external trigger preferred: 24V power C-Mount Best Regards Mirek
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
