1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: record with constant input link
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Ralph Lange via Tech-talk <[email protected]>
Date: Mon, 6 Nov 2023 11:53:50 +0100
Am Mon, 6 Nov 2023 09:32:26 +0100
schrieb Ralph Lange via Tech-talk <[email protected]>:
> Can you set up your low level asyn drivers to connect to the device
> *after* iocInit has been run? Switching them to autoconnect at the end
> of the st.cmd?
Maybe, I probably just fail to see how to do that. I included
"noAutoConnect" in my drvAsynIPPortConfigure:
drvAsynIPPortConfigure("TF1", "localhost:4000", noAutoConnect)
Then after iocInit (last command of st.cmd) I added
asynAutoConnect("TF1", "localhost:4000", yes)
However, this results in lots of error messages tarting with
Cannot find a bus named 'TF1'
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: record with constant input link Gerrit Kühn via Tech-talk
Re: record with constant input link Simon Rose via Tech-talk
Re: record with constant input link Rolf Keitel via Tech-talk
Re: record with constant input link Ralph Lange via Tech-talk
Prev: Re: record with constant input link Ralph Lange via Tech-talk
Next: Re: AlliedVision Manta G-235B Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: record with constant input link Gerrit Kühn via Tech-talk
