1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Sequencer interpretation of PV names with {,} characters
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
To: "Ivashkevych, Oksana" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Nov 2023 11:23:53 +0000
On 03/11/2023 13:25, Ivashkevych, Oksana via Tech-talk wrote:
The dynamic assignment did not change the outcome for me.
Compiles, but can’t connect.
One comment, the dynamic assignment has to go after when() to be understood by the interpreter, otherwise it gives an error.
The dynamic assignment would also work in an entry block, which I believe would be more "correct". You could add one for the "ss" you're creating, so before its first state is entered you have already tried connecting to the PVs.
Sent: Friday, November 3, 2023 12:15 PM
To: Ivashkevych, Oksana <[email protected]>; [email protected]
> Is pvAssign  a version 2.2 addition?
> I see it in 2.2 manual and do not in 2.1.
It’s mentioned in 1.9.  https://epics.anl.gov/EpicsDocumentation/AppDevManuals/Sequencer/snl_1.9_man.html
So 2.1 should be OK.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Sequencer interpretation of PV names with {,} characters Ivashkevych, Oksana via Tech-talk
Re: Sequencer interpretation of PV names with {,} characters Kasemir, Kay via Tech-talk
RE: Sequencer interpretation of PV names with {,} characters Ivashkevych, Oksana via Tech-talk
Prev: Re: record with constant input link Gerrit Kühn via Tech-talk
Next: Re: A Modbus problem relating to byte order and endian Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: Sequencer interpretation of PV names with {,} characters Ivashkevych, Oksana via Tech-talk
Next: Re: Sequencer interpretation of PV names with {,} characters Ralph Lange via Tech-talk
