1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: second relative motion stuck in a do loop
From: "Tran, Phi Dung via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 8 Nov 2023 04:23:36 +0000
I am using RLV for relative motion with a soft channel. When I issue a caput command with a value of 2 to my soft channel, $(P), to move the other real motors, they move by 2 mm. However, when I repeat the caput command with the value 2 to my soft channel for the second time, the motors move by 7*2=14 mm instead of 2 mm. Please advise.
Thank you,
Phi
Attachment: galil0_Ymove_ib_ob_ds.db
Description: galil0_Ymove_ib_ob_ds.db
Re: second relative motion stuck in a do loop Kevin Peterson via Tech-talk
Prev: Re: labjack support, command not found Wolfman, Mark via Tech-talk
Next: caget -d DBR_...INT doesn't work Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: Re: second relative motion stuck in a do loop Kevin Peterson via Tech-talk
ANJ, 09 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
