1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: CS-Studio XY Graph problem with >2046 samples
From: "Heesterman, Peter via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 8 Nov 2023 14:36:14 +0000
I’m using (Eclipse-based) CS-Studio 4.5.9 on Windows, and 4.8.1 within the ITER CS Red Hat installation.
I’m experiencing the same problem for both – when the number of samples in the waveform trace exceeds 2046, the OPI becomes very erratic and fails to display any further data.
Also, the IOC typically fails at the same time.
When this happens, CS-Studio repeatedly shows the error:
2023-11-08 14:01:51 ERROR: Error from pv connection layer:
java.lang.IllegalStateException: transport closed
If CS-Studio is not displaying the OPI, the IOC behaves perfectly for any number of samples.
I’ve also tested the behaviour when using Phoebus, instead of CS-Studio - both the OPI and the IOC then work perfectly.
Does anyone have suggestions as to how this problem might be resolved?
Many thanks,
Peter.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
Re: CS-Studio XY Graph problem with >2046 samples Kasemir, Kay via Tech-talk
Re: CS-Studio XY Graph problem with >2046 samples Mark Rivers via Tech-talk
Re: [EXTERNAL] CS-Studio XY Graph problem with >2046 samples Hartman, Steven via Tech-talk
Prev: caget -d DBR_...INT doesn't work Érico Nogueira Rolim via Tech-talk
Next: Re: CS-Studio XY Graph problem with >2046 samples Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: caget -d DBR_...INT doesn't work Ralph Lange via Tech-talk
ANJ, 09 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
