On 11/10, Jesse Hopkins via Tech-talk wrote:
> We're looking for a way to monitor humidity and temperature in our
> experimental enclosures (beamline hutches), with readings that we can
> access via EPICS. I'd prefer something ethernet based, and low cost is
> always good. I strongly suspect folks in the EPICS community have already
> done this in a variety of ways, though I wasn't able to turn anything
> obvious up in a search.
> Does anyone have a good solution that you're using?
Hi, Jesse!
We use the Esensors Websensor EM01B:
https://eesensors.com/products/websensors/server-room-temperature-monitoring.html
There's an EPICS driver at
https://imca-cat.org/~jlmuir/sw/websensor-em01b.html
Lewis
- Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
Re: [Ext] Re: Room temperature and humidity monitoring with EPICS? Jesse Hopkins via Tech-talk
Re: second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
<2023>
2025
Re: Room temperature and humidity monitoring with EPICS? Gerrit Kühn via Tech-talk
Re: Sequencer website broken Ben Franksen via Tech-talk
<2023>
2025
