1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: synApps build
From: "Lang, Keenan C. via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Siddons, David" <siddons at bnl.gov>
Date: Fri, 17 Nov 2023 16:48:44 +0000
There is a configuration option in AreaDetector within the file AreaDetector/configure/CONFIG_SITE.local,
You can set WITH_PVA=NO in order to build without including the process variable access features introduced in Epics v4
Keenan
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Siddons, David via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, November 17, 2023 10:30 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: synApps build
I'm trying to build synApps on a new PC. I want to use base-3.15.9, but the build fails with:
../ntndArrayConverter.h:5:10: fatal error: pv/ntndarray.h: No such file or directory
    5 | #include <pv/ntndarray.h>
Indeed, I don't see any reference to that file in 3.15.9, only in 7. Does that mean I can't build it on the older distribution? The failure comes from AreaDetector (3-11). The OS is Pop 22.04, which I believe is an Debian/Ubuntu variant.
Pete.
Re: synApps build Siddons, David via Tech-talk
Re: synApps build Mark Rivers via Tech-talk
Prev: synApps build Siddons, David via Tech-talk
Next: Re: synApps build Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 17 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
