Hi Gerrit,
You are missing a way to process the second record.
You can achieve this by providing the PP flag to the OUT link:
field (OUT, "$(CHAN)_DUTY_TEST PP")
Or by using the FLNK on the calcout record (this will result in DUTY_TEST record processing everytime the calcout record processes).
Best regards,
Žiga
> -----Original Message-----
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Gerrit Kühn
> via Tech-talk
> Sent: Wednesday, November 22, 2023 3:33 PM
> To: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
> Subject: Re: "duty cycle" records
> Am Wed, 22 Nov 2023 11:44:03 +0100
> schrieb Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>:
> > So my description was biased. Yep, that happens.
> But it was perfectly reasonable, all fine. :)
> > Small database is a good approach for your size of problem. On the same
> > IOC is good, as you don't have to handle disconnects.
> I guess I still fail to understand how even the simple things work. I have
> made the following for testing now:
> record (calcout, "$(CHAN)_DUTY_CYC") {
> field (DESC, "duty cycled output")
> field (VAL, "10") # 1st cycle time
> field (INPA, "10") # cycle time
> field (CALC, "VAL-1")
> field (OUT, "$(CHAN)_DUTY_TEST")
> field (OOPT, "Transition To Zero")
> field (SCAN, "1 second")
> record (ao, "$(CHAN)_DUTY_TEST") {
> field (VAL, "11")
> The idea was to have the first channel count down seconds from a given
> value and then write out to a diffreent channel and make that one process.
> The countdown works as expected, I can follow it with camonitor. However,
> it looks like the OOPT is never hit even though the counter goes below
> zero. The second channel never changes and stays at the default value "11",
> it looks like it is never written to. What am I doing wrong?
> cu
> Gerrit
- "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Ralph Lange via Tech-talk
- Re: "duty cycle" records Gerrit Kühn via Tech-talk
Re: "duty cycle" records Mark Rivers via Tech-talk
<2023>
<2023>
