Subject: |
sscan R2-11-4 build error on macOS Sonoma? |
"J. Lewis Muir via Tech-talk" <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Thu, 30 Nov 2023 12:40:08 -0600 |
Hello, Tech-Talkers!
I'm building synApps 6.2.1 against EPICS Base 7.0.7 on macOS Sonoma
(14.1.1) on Apple Silicon (EPICS_HOST_ARCH=darwin-aarch64), and the
build fails with an error while building sscan; the end of the build
output is below. I'll keep looking into the issue, but since it's not
immediately obvious to me what's wrong, I thought I'd ask here, has
anyone successfully built sscan on this platform?
Thanks!
Lewis
cc -DUSE_TYPED_RSET -DUNIX -Ddarwin -O3 -g -Wall -Werror-implicit-function-declaration -arch arm64 -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/clang -I../../../include/os/Darwin -I../../../include -I/tmp/build-01/opt/synapps-6.2.1/seq-2-2-9/include -I/tmp/build-01/opt/epics-base-7.0.7/include/compiler/clang -I/tmp/build-01/opt/epics-base-7.0.7/include/os/Darwin -I/tmp/build-01/opt/epics-base-7.0.7/include -c ../saveData_writeXDR.c
../saveData_writeXDR.c:1841:2: error: use of undeclared identifier 'READONLY'
READONLY DBR_VAL * pval = eha.dbr;
../saveData_writeXDR.c:1850:23: error: use of undeclared identifier 'pval'
size= strlen((char*)pval);
../saveData_writeXDR.c:1874:22: error: use of undeclared identifier 'pval'
memcpy(pnode->pval, pval, size);
../saveData_writeXDR.c:1888:2: error: use of undeclared identifier 'READONLY'
../saveData_writeXDR.c:1892:31: error: use of undeclared identifier 'pval'
strncpy(pnode->desc, (char *)pval, MAX_STRING_SIZE);
5 errors generated.
make[4]: *** [saveData_writeXDR.o] Error 1
make[3]: *** [install.darwin-aarch64] Error 2
make[2]: *** [src.install] Error 2
make[1]: *** [sscanApp.install] Error 2
make: *** [/tmp/build-01/opt/synapps-6.2.1/sscan-R2-11-4.install] Error 2
- Re: sscan R2-11-4 build error on macOS Sonoma? Johnson, Andrew N. via Tech-talk
RE: RE: EPICS Archiver Appliance and Channel Filters Sky Brewer via Tech-talk
<2023>
2025
2026
Re: [EXTERNAL] Problem deploying Archiver Appliance Shankar, Murali via Tech-talk
<2023>
2025
2026
