1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Windows 10 LNK1181 error on xml2.lib
To: Freddie Akeroyd - STFC UKRI <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 6 Dec 2023 13:36:13 +0000
Historically and ironically, it seems more troublesome to build EPICS stuff on Windows than on Linux. I saw similar errors quite a while ago.
My colleague, Jakub Wlodek, developed scripts to automate the builds of EPICS base, areaDetector, and other support modules on Windows. Try this: https://github.com/huyong1979/windows-epics-config
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
Date: Wednesday, December 6, 2023 at 7:45 AM
To: [email protected] <[email protected]>
Subject: RE: Windows 10 LNK1181 error on xml2.lib
Does your ioc CONFIG_SITE  include $(AREA_DETECTOR)/configure/CONFIG_SITE ?
Freddie
From: Tech-talk <[email protected]> On Behalf Of Freddie Akeroyd - STFC UKRI via Tech-talk
Sent: 06 December 2023 12:35
  • the “link” command even points to ADSupport/lib/linux-x86_64
I assume you mean ADSupport/lib/windows-x64 ?  And Xml2.lib exists in this location?
Freddie
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: 06 December 2023 08:59
To: EPICS Tech Talk <[email protected]>
On Wed, 6 Dec 2023 at 06:40, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
[...], the “link” command even points to ADSupport/lib/linux-x86_64, and the windows PATH variable points to the same location but still I get the same LNK1181 issue.
Keep in mind that Windows DLLs are in the "bin" install location, while statically linked libraries and the DLL stub libraries are under "lib". Under Windows, PATH needs to point to the DLLs, i.e. should contain the "bin" location.
~Ralph
Re: Windows 10 LNK1181 error on xml2.lib Hu, Yong via Tech-talk
Windows 10 LNK1181 error on xml2.lib Abdalla Ahmad via Tech-talk
Re: Windows 10 LNK1181 error on xml2.lib Ralph Lange via Tech-talk
RE: Windows 10 LNK1181 error on xml2.lib Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: RE: Windows 10 LNK1181 error on xml2.lib Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: Windows 10 LNK1181 error on xml2.lib Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
