1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Pezca documentation, installation
To: [email protected]
Date: Wed, 6 Dec 2023 21:37:30 -0600
Dear tech-talkers,
I am trying to install beamline IOCs and other software in a
simulation PC with hardware links removed in EPICS module database.
Hope this will still provide some degree of testing of non-EPICS
scripts.
New to the beamline and its software, I try to keep all software in
original states, including the perl scripts and its use of Pezca.
The new PC is a RHEL virtual machine in VMware, on a host of Apple M2 Mac.
EPICS base version: 3.14.12.
ezca was installed inside epics/extensions/src/ezca directory,
generated extensions/lib/linux-arm/libezca.a (but not sure how it is
used by Pezca).
But I could not find any documentation over the internet about Pezca
installation.
Tried to create a symbolic link of an old "Pezca.pm" file to
"/usr/lib64/perl5/vendor_perl/Pezca.pm", but it does not work. The
error message of running a perl script is:
Can't locate loadable object for module Pezca in @INC (@INC contains:
/usr/lib64/perl5/vendor_perl /usr/local/lib64/perl5/5.32
/usr/local/share/perl5/5.32 /usr/lib64/perl5/vendor_perl
/usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5) at
/pf/epics/lscat/pezca/attenuationServer.pl line 14.
Compilation failed in require at
The line 14 of "attenuationServer.pl" is:
       use Pezca;
Sharing of Pezca documentation or any suggestions will be appreciated.
Rong
Re: Pezca documentation, installation Rong Huang via Tech-talk
Prev: RE: Windows 10 LNK1181 error on xml2.lib Mark Rivers via Tech-talk
Next: Re: CaSnooper Update? Murray, Doug via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: CaSnooper Update? Murray, Doug via Tech-talk
Next: Re: Pezca documentation, installation Rong Huang via Tech-talk
