Hi Oliver,
I think this is similar to the issue discussed recently in this tech-talk thread:
https://epics.anl.gov/tech-talk/2023/msg01867.php
- The records stay INVALID even if the user attempts to change the values in the input fields.
The record status is INVALID because it has not processed yet.
Your records have SCAN=EVENT. Because SCAN is not PASSIVE then when the user changes the VAL field the record will not process, and hence the status remains INVALID.
- However, the values still do not update when a new one is entered until APPLY is pressed.
The record only sends monitor events for the VAL field when the record processes. Because the record does not process when the user changes the VAL field, it does not send
monitors, and hence the OPI screen does not update.
Copping, Oliver (DLSLtd, RAL, LSCI) via Tech-talk
Sent: Thursday, December 7, 2023 9:48 AM
To: [email protected]
Subject: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget
I have a Menu button widget linked to an MBBO record, that in turn triggers Event records corresponding to whichever option is selected and the APPLYed.
These options are specific motor position configurations for different experiments.
I have a series of AO records that take these position values for various motor positions, each with the SCAN fields set to EVENT.
When their corresponding EVENT is triggered, these AO records are processed, writing their VAL field to the motor demand position.
However, until the APPLY button is pressed, causing the EVENT to trigger, all the records are shown as INVALID.
The values do change in record VAL fields, just not on the screen.
Once the APPLY button is pressed, the records no longer show as INVALID, and show the new values.
Is there a way of making it so the records can be processed, showing the new VALs, without triggering the Events and writing to the motors?
I know I could just separate out the writing to motors to separate records, but then I would be doubling the number of records which isn't ideal.
This is using EPICS R3.14.12.7.
Some examples of the records associated with this:
<records.ao DOL="<PV>:CONFIG" DTYP="Soft Channel" FLNK="<PV>:CONFIG:APPLY:30UM:CALC" OMSL="closed_loop" SCAN="Passive" record="<PV>:CONFIG:APPLY"/>
<records.event EVNT="1" record="<PV>:CONFIG:30UM:APPLY"/>
<records.ao EVNT="1" OUT="<MOTOR_PV>:Y PP" SCAN="Event" VAL="38.6839" record="<PV>:CONFIG:30UM:MAPTY"/>
<records.calcout CALC="A = 0 ? 1 : 0" INPA="<PV>:CONFIG:APPLY" OEVT="1" OOPT="When Non-zero" record="<PV>:CONFIG:APPLY:30UM:CALC"/>
Software Systems Engineer
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt
by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
