1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Fwd: Raising alarms with P4P
From: "Claus, Ric via Tech-talk" <[email protected]>
Date: Fri, 8 Dec 2023 23:56:58 +0000
Hello,
 I have written a PV server using P4P based on the lazycounter_server_cothread.py example in the P4P repository.  It uses NTScalars with the valueAlarm option set to True.  I am able to set valueAlarm fields through both the program and pvput commands and then see the results with pvget:
$ pvget -vv DAQ:NEH:tst:3:test_pv
DAQ:NEH:tst:3:test_pv epics:nt/NTScalar:1.0
   uint value 2
   alarm_t alarm
       int severity 0
       int status 0
       string message
   time_t timeStamp 2023-12-08 10:04:59.245
       long secondsPastEpoch 1702058699
       int nanoseconds 244999885
       int userTag 0
   structure valueAlarm
       boolean active true
       uint lowAlarmLimit 2
       uint lowWarningLimit 0
       uint highWarningLimit 0
       uint highAlarmLimit 4
       int lowAlarmSeverity 3
       int lowWarningSeverity 0
       int highWarningSeverity 0
       int highAlarmSeverity 3
       double hysteresis 0
However, I don’t see the alarm structure’s fields changing (although I’m not sure what to expect).  Where should the alarm evaluation occur?
I found this comment in the Normative-Types-Specification page:
Code that checks for alarms should use code similar to the following:
followed by some C code showing how to do the alarm evaluation (without hysteresis) and raising.  Is it the intention that similar code should be in the application layer of my PV server, rather than in some common lower layer?  If so, how should this be done since I haven’t found the equivalent of some of these routines in P4P?
Thank you for any guidance you can give me!
Ric Claus
SLAC/LCLS
Re: Fwd: Raising alarms with P4P Michael Davidsaver via Tech-talk
Prev: Re: Simulated limit switches on motorSim motor Torsten Bögershausen via Tech-talk
Next: Re: Fwd: Raising alarms with P4P Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: EPICS Event Scan Field causes EDM PV readback to not update in Text Entry widget Johnson, Andrew N. via Tech-talk
