1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Crash when caput array of string to pcaspy or PCAS server tool
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 14 Dec 2023 09:54:17 +0100
On Thu, 14 Dec 2023 at 09:48, Wang, Lin <wanglin at ihep.ac.cn> wrote:
A regular IOC with the following waveform record works properly with the caput CLI comes with EPICS 3.14.12.8 or EPICS 7.0.7.
record(waveform, "wfExample")
        field(DTYP, "Soft Channel")
        field(FTVL, "STRING")
        field(NELM, "3")
        field(INP, ["aaa", "bbb", "ccc"])
Hm...
Can you double check if that is a single element ("xxx yyy zzz") or three elements ("xxx", "yyy", "zzz") in the record? (Might look the same on the command line.)
Cheers,
~Ralph
Re: Crash when caput array of string to pcaspy or PCAS server tool Wang, Lin via Tech-talk
Re: Crash when caput array of string to pcaspy or PCAS server tool Ralph Lange via Tech-talk
Prev: Re: Crash when caput array of string to pcaspy or PCAS server tool Wang, Lin via Tech-talk
Next: is there an EPICS module to makePvToArchiveFromDbInfo() ? NADOT Victor via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: Crash when caput array of string to pcaspy or PCAS server tool Wang, Lin via Tech-talk
ANJ, 14 Dec 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
