Hi Victor,
If you use a recent version of base, you can list tags on the IOC shell and write them to a file:
epics> dbli *archive*
ST99:Det:IOC_SADet3:Status info(archive, "Monitor, 00:00:01, VAL")
ST99:Det:IOC_SADet3:StatCtrl info(archive, "Monitor, 00:00:01, VAL")
ST99:Det:IOC_SIDet3:STATUS info(archive, "Monitor, 00:00:01, VAL")
ST99:Det:IOC_SIDet3:STATCTRL info(archive, "Monitor, 00:00:01, VAL")
epics>
epics> dbli *archive* > /tmp/archive_list.txt
cat /tmp/archive_list.txt
Then you can parse that list and generate an archive configuration. Or, modify an archiver to be able to read that format.
We use a Python script to parse the database files, but if we were starting today I'd probably use the above method as the first step in extracting the info tags.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Simon Rose via Tech-talk
Sent: Thursday, December 14, 2023 5:23 AM
To: NADOT Victor <VICTOR.NADOT at cea.fr>; tech-talk at aps.anl.gov
Subject: [EXTERNAL] Re: is there an EPICS module to makePvToArchiveFromDbInfo() ?
Hi Victor -
There is one that we have used at ESS that might serve your purpose:
https://urldefense.us/v2/url?u=https-3A__gitlab.esss.lu.se_icshwi_iocmetadata&d=DwIGaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=aEDRFW1J1RKf3L4Vy5iLgaY2FJpZ2TV1XDtc_tKxW00&m=vNISIrtmTSvaQHTNeWDl1p15L43in4-yA1-44ChtrvumzGayCjG4ekJITH08uJbN&s=CH3zpoO636P0uNZGzJnegnwLIRfFkNbkML82l2Cap0E&e=
Note that it uses EPICS 7 NT types. There is pretty good documentation in the README file in the repository.
Cheers,
Simon
On 2023-12-14, 10:29, "Tech-talk on behalf of NADOT Victor via Tech-talk" <tech-talk-bounces at aps.anl.gov <mailto:tech-talk-bounces at aps.anl.gov> on behalf of tech-talk at aps.anl.gov <mailto:tech-talk at aps.anl.gov>> wrote:
Hi all,
is there an EPICS module to, in the same way as `makeAutosaveFileFromDbInfo()` works, generate (at IOC boot, so macro are resolved) a file with a list of PV names to archive from the information provided in the record `info()` field ?
```epics
record(ai, "MyPv") {
info(archive, "YES")
This would be a nice tool to then copy/past all the pv list files to archive in the archiver.
Thanks for the answer,
Cheers,
Victor Nadot
Ingénieur Systèmes Electroniques Embarqués CEA Saclay - DRF / IRFU / DIS / LDISC Bâtiment 472 - pièce 120
+ 33 (0)1 69 08 41 88
+ 33 (0)6 45 03 12 54
- Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? Tynan Ford via Tech-talk
- is there an EPICS module to makePvToArchiveFromDbInfo() ? NADOT Victor via Tech-talk
- Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? Simon Rose via Tech-talk
Re: Crash when caput array of string to pcaspy or PCAS server tool Wang, Lin via Tech-talk
<2023>
2025
<2023>
2025
