1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: IP520 not communcating with baud rates other than 9600bps
From: Mrinal Bera via Tech-talk <[email protected]>
To: Tech-talk <[email protected]>
Cc: Daniel Henry Solz Kerr <[email protected]>
Date: Thu, 21 Dec 2023 19:39:03 +0000
Dear All,
I would like to bring to your attention some issues that we are facing while setting up IP520 with AVME 9600 for serial ports with
1) vxWorks 6.9.4.1
2) EPICS 7.0.7
3) asyn-R4-42
4) ipac-2-16
5) ip-R2-21-1
6) compiled on the host running CentOS Stream 9
Here is the part of the startup script we used to set the serial with IP520:
ipacAddAvme96XX("0x0800,4 R”)
IP520Drv(1)
IP520ModuleInit("UART1", "232", 0x81, 1, 0)
IP520DevCreate("serial9", "UART1", 0, 512, 512)
drvAsynSerialPortConfigure("serial9","serial9",0,0,0)
asynSetOption("serial9", -1, "baud", "9600")
asynSetOption("serial9", -1, "bits", 8)
asynSetOption("serial9", -1, "parity", "none")
asynSetOption("serial9", -1, "stop", "1")
asynSetOption("serial9", -1, "clocal", "Y")
asynSetOption("serial9", -1, "crtscts", "N")
asynOctetSetInputEos("serial9", -1, "\r")
asynOctetSetOutputEos("serial9", -1, "\r”)
With the above settings, everything works fine in terms of communicating with the serial port both with loopback and with any device. Then we found that if we change the baud rate setting of the serial port in any of the following ways the communication stopped working:
1) Change the baud rate settings through asynRecord.adl after booting vxWorks with 9600bps as shown in the settings above.
2) Boot vxWorks with a baud rate setting of the serial port other than 9600bps.
The only way to make the serial port work again is to reboot the vxWorks with the baud rate of 9600pbs.
We tried to look at the signal from IP520 using an oscilloscope and we found that the signal out of IP520 changes normally as the baud rates are changed. Hence, we suspect that the problem is with the reading of the signals by IP520 when set up with baud rates other than 9600bps.
Did anybody try other baud rates than 9600bps with IP520?
Thanks and regards,
Mrinal
Mrinal Kanti Bera, PhD
Beamline Scientist & Research Associate Professor
NSF’s ChemMatCARS, Pritzker School of Molecular Engineering
University of Chicago
9700 S Cass Ave Bldg 434D
Argonne, IL-60439
United States
Phone: +1-630-252-0472
Prev: Re: asyn ioctestIPServer prints many accept errors after IOC exit? J. Lewis Muir via Tech-talk
Next: Re: Steps for installing any EPICS Device Support module Eusebio Naif Al-Soliman Fuentes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: StreamDevice+regex for escaping and unescaping HEX messages Sebastian Eckert via Tech-talk
