1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Question about cross compile of epics
To: [email protected]
Date: Thu, 28 Dec 2023 10:35:06 +0900
Hello epics users,
These days I try to do the cross compile from linux x86 to linux-arm. My host computer uses ubuntu system but the target device use the arm architecture so I try to do the cross compile.
I used epics in usual x86 system or rasberrypi but I have not used the cross compile in epics. Therefore, I can not imagine the sequence of the cross compile in epics.
If I want to use the cross compile at epics, should I do the cross compile for the epics-base and other supporting modules like asyn, sequencer, autosave, and etc?
If that is right, I also face some other problem in epics-base compile. It compiled well but it face some problem when I give cross compile option.
At first I set the "CROSS_COMPILER_TARGET_ARCHS=linux-arm" at /configure/CONFIG_SITE and type  "export CROSS_COMPILE=arm-linux-gnueabihf-", "export ARCH=arm" to do make.
However, it says they can not found 'arm-xilinx-linux-gnueabi-gcc'. I installed the  'arm-linux-gnueabihf' because I heard that the target device has hard float. Does the error comes out because of some path? or is there any setting, I should do?
Best Regards
SeokHo Moon
Prev: Re: StreamDevice+regex for escaping and unescaping HEX messages Zimoch Dirk via Tech-talk
Next: Re: Investigating performance issues with Xflash detector IOC on Windows 10 Rami Khrais via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
