1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: [EXTERNAL] Representing stateless device commands?
From: "Hartman, Steven via Tech-talk" <[email protected]>
To: "Feister, Scott" <[email protected]>
Date: Sat, 6 Jan 2024 00:29:18 +0000
Check the EPICS Record Reference documentation for details on the binary output record. It has a field “HIGH” which specifies the time in seconds for the BO record to remain asserted before resetting itself to zero automatically.
Steven Hartman
hartmansm @ornl.gov
Sent: Friday, January 5, 2024 7:11 PM
To: Hartman, Steven <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: [EXTERNAL] Representing stateless device commands?
Thanks Steven and Mark, for your welcoming and helpful responses.
I have the streamDevice proto files written, and am at the point where I’m wondering if there’s an easy way to capture what Steven is suggesting – forcing the PV back to zero immediately after the RS232 command “IncreaseBrightness” has been sent, such that the state of the binary PV “MYLED:IncreaseBrightness” represents whether we are “in process” of “Increasing Brightness”?
Here’s what I have in mind as far as sequence:
  1. “MYLED:IncreaseBrightness” is 0, its regular state.
  2. I invoke “caput MYLED:IncreaseBrightness 1”, changing the PV from 0 to 1.
  3. StreamDevice follows its protocol for processing a change in the PV, and sends an RS232 message of “IncreaseBrightness” to the device. StreamDevice awaits no reply, as the device gives none.
  4. [Somehow?] “MYLED:IncreaseBrightness” is now automatically forced back to 0.
I have steps 1-3 under control with StreamDevice, so I’m wondering about best practices to implement Step 4.
Thanks!
Scott
Sent: Friday, January 5, 2024 1:22 PM
To: Feister, Scott <[email protected]>
CAUTION: This email originated from outside of CSUCI. Do not click links or open attachments unless you validate the sender and know the content is safe. Contact ITS if you have any concerns
On Jan 5, 2024, at 1:47 PM, Feister, Scott via Tech-talk <[email protected]> wrote:
My approach right now is to call them binary outputs (bo) records
Welcome to the forum.
Yes, that sounds about right.
You can use the ONAM and ZNAM fields of the BO record to name the two states which may convey that it is indeed a process variable that is either doing something (i.e., increase the brightness) or not. In EPICS, pretty much everything is a process variable.
Steven Hartman
RE: [EXTERNAL] Representing stateless device commands? Feister, Scott via Tech-talk
Re: [EXTERNAL] Representing stateless device commands? Hartman, Steven via Tech-talk
Prev: RE: [EXTERNAL] Representing stateless device commands? Feister, Scott via Tech-talk
Next: RE: [EXTERNAL] Representing stateless device commands? Feister, Scott via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
