1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: OPC UA build problem
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 11 Jan 2024 09:04:59 +0100
Dear Vivien,
On Wed, 10 Jan 2024 at 16:02, LORIOT Vivien via Tech-talk <[email protected]> wrote:
c++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3   -Wall    -DEPICS_NO_CALLBACK -DHAS_XMLPARSER -std=c++11 -fdiagnostics-color=always -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../devOpcuaSup -I../../devOpcuaSup/open62541 -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/compiler/gcc -I/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/os/Linux -I/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include    -I../../devOpcuaSup/open62541 -I/usr/include/libxml2 -I/volatile/home/vl276037/Top/open62541-1.3.9/install/include    -c ../opcuaItemRecord.cpp
../opcuaItemRecord.cpp:186:6: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
  186 | rset opcuaItemRSET = {
In file included from /nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/dbBase.h:22,
                 from /nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/dbAccess.h:20,
                 from ../opcuaItemRecord.cpp:19:
/nix/store/3jdcplbpdj2177csm7nbw3prjlaq1bdn-epics-base-7.0.7/include/recSup.h:89:21: note: declared here
   89 | typedef struct rset rset EPICS_DEPRECATED;
../opcuaItemRecord.cpp:190:20: error: invalid conversion from ‘long int (*)(dbCommon*, int)’ to ‘long int (*)()’ [-fpermissive]
  190 |     RECSUPFUN_CAST(init_record),
      |                    long int (*)(dbCommon*, int)
../opcuaItemRecord.cpp:43:31: note: in definition of macro ‘RECSUPFUN_CAST’
   43 | #    define RECSUPFUN_CAST(F) F
In the OPC UA Device Support module, CONFIG_SITE defines '-DUSE_TYPED_RSET' for C++ compilation. [1]
That definition is missing on the compile line you are showing above - it probably slipped your migration to the Nix build system.
In case you are supporting Secure OPC UA: Other users are having issues with recent Linuxes (new API of openssl) and the Open62541 release 1.3, which show as crashes when the IOC starts. If you get it working, I'd be interested to know the details of your setup.
Cheers,
~Ralph
Re: OPC UA build problem Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
OPC UA build problem LORIOT Vivien via Tech-talk
Prev: Portable Channel Access Server for Node.js Wang, Lin via Tech-talk
Next: Thorlabs MFF101 Motor Device Support Matt Shaw - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: OPC UA build problem LORIOT Vivien via Tech-talk
Next: Re: OPC UA build problem Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
