Sent: Wednesday, January 10, 2024 11:05 AM
To: [email protected]; Henrique F. Simoes
Subject: Re: GNU/Linux and GigE camera settings for high-throughput with ADAravis
> Hi Enrique,
> As James said, you should increase net.core.rmem_default, not just net.core.rmem_max. This is documented in the ADGenICam documentation
> https://areadetector.github.io/master/ADGenICam/ADGenICam.html#linux-usb-and-gige-system-settings
Thank you and James for highlighting this! It turns out to be the missing piece
in the deployment machine. After rerunning with this setting, I could then
achieve 7.4Hz lossless acquisition (~500k images).
> Here are some suggestions:
> * Is the camera on a network with other devices, or a dedicated NIC on the Linux machine? If on a shared network how many switches between the camera and IOC machine? If there are shared links other network traffic could be the problem. A dedicated NIC is often a good solution.
For those tests, I was using a dedicated NIC, with the camera traffic going
through a single switch before reaching the IOC machine. No links should be
shared, as far as I know, even though the switch itself is not dedicated.
In a final setup, though, we will run two IOCs in the same machine for two
cameras of the same model. But I'm not expecting both of them to operate at
full throughput. Having a single one operate at its limit makes me more
confident that the result we will observe is close to the maximum possible.
> * You can try using ADVimba rather than ADAravis. It may have more optimized network handling.
In the beginning, I ran an ADVimba IOC with this camera, but its failure rate
was way higher than with ADAravis. I came to the point of single frame
acquisitions not working (as the first frame would frequently drop). That was
before I realized the issues I was noticing were only due to the network
performance.
> * If you use ADVimba you can make the camera run in color mode at the full 23 frames/s. You do that by using Bayer mode to read the camera, and do the conversion to RGB in the IOC, rather than on the camera. This reduces the network traffic by a factor of 3.
That's a nice option to reduce traffic for color cameras. In terms of reducing
network traffic, I've already used ROI (also described as AOI by some
manufacturers) cropping done on the camera. Binning is another option, even
though I haven't tested it yet. All of them reduce in some level the amount of
information provided, and depend on the specific usage, though.
> ADAravis does not currently support this option.
Converting Bayer to RGB is (conceptually) general enough to be refactored (at
least) to ADGenICam, isn't it?
Best regards,
Henrique F. Simões
> Mark
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Re: GNU/Linux and GigE camera settings for high-throughput with ADAravis Mark Rivers via Tech-talk
- GNU/Linux and GigE camera settings for high-throughput with ADAravis Henrique F. Simoes via Tech-talk
Re: GNU/Linux and GigE camera settings for high-throughput with ADAravis Henrique F. Simoes via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
