1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: S7PLC drivers PSI documentation
From: Ralph Lange via Tech-talk <[email protected]>
To: Dirk Zimoch <[email protected]>
Date: Fri, 12 Jan 2024 08:58:28 +0100
On Fri, 12 Jan 2024 at 08:47, Žiga Oven via Tech-talk <[email protected]> wrote:
Looks like that the documentation moved into the `S7plcApp/src/` when the module was restructured to look more like an EPICS module.
https://github.com/paulscherrerinstitute/s7plc/blob/master/S7plcApp/src/s7plc.html
Morning Dirk,
Would you be able to set up a CI job that pushes the s7plc documentation to GitHub-pages, similar to what you did for StreamDevice?
I think this would be safer concerning restructured institute web appearances, cyber-attack-induced shutdowns and similar events.
Thanks for considering,
~Ralph
S7PLC drivers PSI documentation SAINTIN Katy via Tech-talk
RE: S7PLC drivers PSI documentation Žiga Oven via Tech-talk
Prev: RE: S7PLC drivers PSI documentation Žiga Oven via Tech-talk
Next: Re: s7nodave-3.0.2 compilation error Vishnu Patel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: autosave - Normative Types support? Gabriel Fedel via Tech-talk
