1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: drv_libera_env.c file of Libera Single Pass
From: Hatice İrem Nalçak via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 15 Jan 2024 11:20:21 +0300
Hello,
I am working on the Libera Single Pass. When I run the IOC in device's terminal following errors appear:
./runapp.sh
#!/opt/epics-libera/bin/linux-arm/libera
epicsEnvSet(ARCH,"linux-arm")
epicsEnvSet(IOC,"iocLibera")
epicsEnvSet(TOP,"/opt/epics-libera")
epicsEnvSet(EPICS_BASE,"/opt/epics-libera")
cd /opt/epics-libera
dbLoadDatabase("dbd/liberaSupport.dbd",0,0)
liberaSupport_registerRecordDeviceDriver(pdbbase)
### PORT INITIALIZATION
# Environment port
liberaInit("ENV","ENV", "0", "0", "0", "0", "1")
../drv_libera_env.c:72 CSPI error in cspi_getenvparam: system-level call failed (-5), No such file or directory (2)
Error ENV retrieving data
../drv_libera_env.c:1069 CSPI error in cspi_setconparam: unknown error (-1), No such file or directory (2)
Error setting params to handle events
# Fast Application port reading/writing 8192 samples
liberaInit("FA","FA", "0", "8192", "0", "0", "1")
# ADC port reading 1024 samples
liberaInit("ADC","ADC", "0", "1024", "0", "0", "1")
../drv_libera_adc.c:343 CSPI error in cspi_setconparam: unknown error (-1), No such file or directory (2)
# Slow Acquisition port
liberaInit("SA","SA", "0", "0", "0", "0", "1")
#asynSetTraceMask("SA",0,0x1f)
#asynSetTraceIOMask("SA",0,0x7)
## Load record instances
cd db
dbLoadTemplate("libera.substitutions")
iocInit()
Starting iocInit
## EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Jan 26 2011
############################################################################ ../drv_libera_env.c:92 CSPI error in cspi_getenvparam: system-level call failed (-5), No such file or directory (2)
../drv_libera_env.c:844 CSPI error in cspi_setenvparam: system-level call failed (-5), No such file or directory (2)
Error ENV setting params for command 724, mask 10000
2024/01/11 01:50:51.510 LIBERA01:ENV:ENV_GAIN_SP devAsynInt32 process error
Error ENV setting params for command 725, mask 20000
2024/01/11 01:50:51.520 LIBERA01:ENV:ENV_AGC_WRITE devAsynInt32 process error ../drv_libera_env.c:92 CSPI error in cspi_getenvparam: system-level call failed (-5), No such file or directory (2)
iocInit: All initialization complete
epics> ../drv_libera_env.c:92 CSPI error in cspi_getenvparam: system-level call failed (-5), No such file or directory (2)
I seached for drv_libera;-env.c file. There is no source file or any sign for CSPI in the source directory but it seems like object files exist in static libraries:
 grep -rni 'drv_libera_env.c' /opt
Binary file /opt/epics-libera/lib/linux-arm/libliberaSupport.a matches
Binary file /opt/epics-libera/lib/linux-arm/libliberaSupport.so matches
It would be great if you can help me with this.
Irem
Re: drv_libera_env.c file of Libera Single Pass Johnson, Andrew N. via Tech-talk
Prev: EPICS controls website expired certificate Luka Peruško via Tech-talk
Next: Re: EPICS controls website expired certificate Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: EPICS controls website expired certificate Ralph Lange via Tech-talk
Next: Re: drv_libera_env.c file of Libera Single Pass Johnson, Andrew N. via Tech-talk
