1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: ADVimba CPU usage
From: Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 17 Jan 2024 09:47:36 +0000
Hi Mark
Thanks for your response.
Please provide the following:
  • The versions of ADCore and ADVimba
    • ADCore - R3-8, ADVimba - Ahead of R1-3 at commit 17dcdb1 dated Jun 30, 2022
  • Is this Windows or Linux?
    • Linux
  • How many cores on the IOC machine?
    • 20 cores
  • When you say 75% of the CPU do you mean 75% of a single core, or 75% of all cores?
    • 75% of all cores... as evident from command "glances"
  • When you remove the external trigger what frame rate are the cameras getting?  It should be 0.
    • FrameRate_RBV is 10 (that's what it's set. I tried setting framerate to zero and still the same CPU usage) but ImageRate_RBV is 0.
  • A screenshot of the AVVimba screen when the problem is happening
    • Attached with Mail.
  • A screenshot of the commonPlugins OPI screen when the problem is happening so we can see what plugins are running and at what rate.
    • I am using Trans, Stats, Overlay and NDStdArray Plugins and the rate is 0 under this scenario.
  • A screenshot of "top -h" in the IOC computer when the problem is happening on.  This will show us what threads are using the CPU.
    • Attached with the mail
Many Thanks
Sandeep
Sent: 16 January 2024 20:57
Cc: EPICS tech-talk <[email protected]>; Malu, Sandeep Kumar (-,RAL,CLF) <[email protected]>
The command I meant is “top -H”, not -h.
On Jan 16, 2024, at 8:47 AM, Mark Rivers via Tech-talk <[email protected]> wrote:
Hi Sandeep,
Please create an issue for this problem here: https://github.com/areaDetector/ADVimba/issues
I just did a quick test of a GC1380CH camera with ADVimba.  It used 30% of 1 core when running at 30 frames/s.  I had only NDPluginPVA running.  When I stopped the camera acquisition the CPU dropped to 0%, as I expected.  When I selected external trigger but have no trigger pulses arriving I also get 0 frames/s and 0% CPU, as I expect.
From: Tech-talk <[email protected]> on behalf of Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
Sent: Tuesday, January 16, 2024 6:08 AM
To: EPICS tech-talk <[email protected]>
Subject: ADVimba CPU usage
Hi All
I have been using ADVimba Areadetector driver for AVT MakoG234C (1936x1216) Cameras. 15 cameras are running with external triggers of 10 fps and the CPU usage is ~27%.
However, when I deployed those 15 cameras keeping the external trigger (from the delay generator) off, the CPU usage drastically goes up to ~75%. Also, I noticed the same behaviour when Acquire is OFF or switched to Software Trigger source.
Has anyone seen this behaviour when the driver is not actually acquiring the images? Is there any solution to this drastic CPU usage?
Many Thanks
Sandeep
Attachment: ADVimba.png
Description: ADVimba.png
Attachment: topH.png
Description: topH.png
Re: ADVimba CPU usage Mark Rivers via Tech-talk
ADVimba CPU usage Sandeep Kumar Malu - STFC UKRI via Tech-talk
Prev: Re: Generic EPICS IOCs Andrea michelotti via Tech-talk
Next: Questions about creating a Model 3 Driver for stepper motor axis Paul-Elie GUILLOT via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: ADVimba CPU usage Mark Rivers via Tech-talk
Next: Re: ADVimba CPU usage Mark Rivers via Tech-talk
