1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Generic EPICS IOCs
From: Timo Korhonen via Tech-talk <[email protected]>
To: Han Lee <[email protected]>, "Knap, Giles (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Thu, 18 Jan 2024 11:30:44 +0000
Dear Han and all,
I am sorry if I pushed you, Han, too much with E3 development. We appreciate a lot the work you did and have been building upon it.
The environment has evolved really well and we are now running over 1000 IOCs with it. There are sooo many things I like about our setup that I cannot put them all in an email. I just write here that:
  • First of all, it is stable – this is a worry that I hear from many people. I am not exactly sure why, maybe because modules are loaded at IOC startup. But pretty much every modern software does that.
  • It makes it very easy to keep our IOCs up to date, especially when it comes to updating common infrastructure modules like recsync, logging services, etc. No need to hunt down the IOC developer (who may have left) to rebuild the IOC. System-specific modules can be left untouched.
  • The development and deployment processes are unified, we can easily track down what modules and which versions each IOC is using.
  • New integrators, or IOC engineers, state that they prefer this approach to the “vanilla” method. This has been a big thing for us.
  • Every IOC instance is very “thin”, basically consisting of a startup script and a few configuration files.
  • etc. etc. I could go on for a long time. But in fact, I would like my colleagues to present their work instead of me writing.
And by the way, the system also supports Area Detector, which saves many IOC engineers from the trouble of figuring out the compilation details.
One more thing to be added is that what makes our setup work so well is integration with our deployment and monitoring system. E3 is only one part in the puzzle.
Of course, this comes with a price of having a group of people to build and support that. That said, most of the work is done if anybody would like to try it out, it is not necessary to start from scratch. And to be honest, it has required a lot of work. I would say though that the investment has paid off. It would not have happened if we did not have the talented developers that have done amazing work on it.
But for each their own. If people prefer to compile each individual IOC, or use some other method, OK with me.
I just know that E3 works for us, and works very well. It has rescued us from the initial chaos we had at the time when you were with us, Han.
Best regards,
Timo
ps. E3 would probably work in a container environment as well, I was pointed out. Then the containers could be truly versatile.
From: Tech-talk <[email protected]> on behalf of Han Lee via Tech-talk <[email protected]>
Reply to: Han Lee <[email protected]>
Date: Wednesday, 17 January 2024 at 18:44
To: "Knap, Giles (DLSLtd,RAL,LSCI)" <[email protected]>
Hi Giles,
As a person who designed and laid down the fundamental ground of the E3 under the vision of my beloved chief engineer, Timo, I got your point well.
The E3 is the ESS EPICS Environment diverted from and based on the PSI EPICS Environment.
However, personally, I wouldn't say I like that approach. ;)
Each site has its issues in selecting whatever approaches were established. It will be fine if your site has enough resources and pieces of knowledge to maintain them.
The EPICS collaboration meeting is where you can share your work with our community. I think you should share your architecture at upcoming events. Then, sometimes, you can find a group of people who are interested in your architecture.  During events, you can enjoy sharing your vision with them as well.
Best,
Han
On Wed, Jan 17, 2024 at 7:19 AM Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]> wrote:
Thanks for all the responses.
I'll try to address as many of the points as I can.
Our approach is to have a very flat structure, an EPICS base container and then one container that compiles the support for a particular class of device plus all of the dependencies of that support. It will also install Debian packages for any  system dependencies if required.
We experimented with a more hierarchical structure initially but container dependency management became unwieldy.  Instead, having all support modules compiled together so that the dependencies are all inside the one container really simplifies things. (Perhaps I could draw parallels to the way Arch Linux installs things)
One example that we have extensively tested is GigE cameras which use the ADAravis support module. You can see how this is made in the Dockerfile here  https://github.com/epics-containers/ioc-adaravis/blob/main/Dockerfile. Note that we include some generally useful support like autosave and iocStats.
It is absolutely the case that this is targeting a device that we have hundreds of and it is beneficial to this site to only have to compile it once then deploy multiple times. Each beamline has a repo of ioc instances that are described using YAML. Deploying the IOC instance is a matter of telling Kubernetes to combine the generic ADAravis container with some config that specifies which camera to connect to, what PV prefixes to use and which  areadetector plugins you want. These choices determine what the
startup script and Database look like.
The generic IOC concept works for this case but the framework can also have individual IOCs. You can make a specific IOC container image using a Dockerfile that combines whatever support you want and embed the yaml description (or traditional startup script/ DB if preferred).  Or you can make your specific IOC image by deriving from a Generic IOC and adding whatever you please.  Containers are perfectly good at inheritance, but not that good for composition. I don't know anything about E3 and would appreciate some pointers as it sounds like it is handling the composition problem.
So the generic  IOC is there to keep down the proliferation of container images, but the benefits of using containers and orchestration are still valuable even if you have mostly individually built containers. Clearly whenever individually compiled code like Sequencer state machines etc are involved, this needs a non-generic container.
One of the ways we are mitigating need for custom combinations of support is that we are as far as possible making fine grained IOCs that are one to one with a device. Historically DLS diagnostic camera IOCs managed a hutch or two's worth of cameras, those are being split into one per camera.  Kubernetes is good at managing lots of small services and allocating CPU/Memory resources accordingly.
I'll finish by retracting the phrase "viable for use in any facility" and replace with "viable for use at more than one facility"  :-)
giles
From: Tech-talk <[email protected]> on behalf of Andrea michelotti via Tech-talk <[email protected]>
Sent: 16 January 2024 17:39
To: [email protected] <[email protected]>
Hello,
At INFN-LNF, we adopted dockerization and Kubernetes in 2019 to efficiently manage one of our beam test facilities using our custom control system, !CHAOS. Through our experiences, we have become increasingly convinced of the benefits offered by a dockerized and orchestrated approach in control systems. I think this is especially valuable in addressing and mitigating the complexities introduced by an older, non-object-oriented control system like EPICS.
Considering our limited manpower for supporting custom control systems in upcoming accelerator infrastructures, we have decided to embrace EPICS, despite being relatively new to it. Starting afresh, our goal is to blend new technologies with the utilization of EPICS. We closely follow Giles' initiatives at Diamond and actively work to integrate his proposed workflows into our own, aiming for generality and maximum reuse of controls. I particularly appreciate the idea of having a tool like ibek that allows instantiation of IOCs from .yaml(s). This, combined with support for 'generic containers', offers a clean and efficient way to create 'reusable controls.'
Best regards,
Andrea
Il 15/01/24 12:36, Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk ha scritto:
Good day All,
I would like to canvas opinion on the viability of the concept of Generic IOCs.
At DLS, we have been working on moving our IOCs to Kubernetes for a while.  Part of our approach is to use the concept of Generic IOCs for our container images as follows:
  • We build all the support for a given class of device into a single container image. This 'Generic IOC' has an IOC binary but no startup script or EPICS DB.
  • An IOC instance is a pointer to a Generic IOC image plus enough information to generate the startup script and DB at runtime.
So this means that we have a generic version of epics base built into a container image and then one generic IOC container image based upon that for each device. In none of these are any site specific changes made, all the source we use is upstream and untouched (with one or two small exceptions for compilers to work in our base OS).
The intention is that these Generic IOCs are viable for use in any facility that chooses to use containers to deploy its IOCs (using any container runtime that is OCI compliant).
Is this a bad idea? are there site specific options that cannot be avoided, and cannot be applied at runtime?
Any thoughts much appreciated.
giles
dr. Andrea Michelotti
Head of Control Systems Service
INFN - Laboratori Nazionali di Frascati
Accelerator Division,
Bldg.2, Room 120
Via Enrico Fermi, 40
00044 Frascati (RM)
e-mail:   [email protected]
office:   (+39) 06.9403.2272
mobile:   (+39) 06.9403.8203
fax   :   (+39) 06.9403.2256
Teams :   [email protected]
LinkedIn: http://it.linkedin.com/in/michelotti
Jeong Han Lee, Dr.rer.nat.
Staff Scientist and Engineer
Cell: +1 510 384 3868
https://orcid.org/0000-0002-1699-2660
Re: Generic EPICS IOCs Ralph Lange via Tech-talk
Re: External: Re: Generic EPICS IOCs Niko Kivel via Tech-talk
Generic EPICS IOCs Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Re: Generic EPICS IOCs Andrea michelotti via Tech-talk
Re: Generic EPICS IOCs Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Re: Generic EPICS IOCs Han Lee via Tech-talk
Prev: Re: ADVimba CPU usage Sandeep Kumar Malu - STFC UKRI via Tech-talk
Next: Re: Generic EPICS IOCs Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: Generic EPICS IOCs Han Lee via Tech-talk
